Overheating and stumped
Old May 6, 2005 | 11:00 PM
Bruticus's Avatar
Ok My car has been overheating and I am stumped and need a little help. Ok first off the cooling fan isnt coming on when its suppose too. So I took a paper clip and did the test the fan came on so ok I figured it was the Fan Relay. I buy the relay installed it Fan never came on.
So my question is how man relays are there for the fans are there 3 one for each fan and the relay thats on the driver side by the fuel pump relay ?
I also changed the hoses and CTS any help pictures or anything will be useful thanks.
Old May 6, 2005 | 11:02 PM
TheZ's Avatar
Car: 86 Iroc-Z
Engine: 5.0 TPI
ther should be a relay for each fan, but im realy not sure
Old May 7, 2005 | 01:58 PM
mikesirocz's Avatar
Car: 85 Camaro IROC-Z
Have you looked at the fan switches?
Old May 7, 2005 | 03:26 PM
Bruticus's Avatar
Ok thats something I havent done where are they located at ?
Old May 7, 2005 | 03:46 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
On the p/s between the back two spark plugs, screwed into the block is a fan switch. Pull the wire off of it, and with the key in the on position (don't start it), touch the wire to ground. The fan should come on. If not you could have a bad fan switch. I like the hypertech fan switch from summit racing. Turns the fan on much sooner than stock.
Old May 7, 2005 | 03:52 PM
Bruticus's Avatar
Ok bear with me I am a bit new to this so your saying in the back of the engine between the 2 spark plugs is where its located. Almost like the temp switch for the gauge only thats in the front of the engine. So I would put my car in the On position and disconnect the wire from the switch and touch the wire to the ground. I am no electrical genius so where would the ground be ?
Old May 7, 2005 | 05:08 PM
rlrepitman's Avatar
Car: 1987 Camaro SC
Engine: LG4 305
Transmission: TH700R4
You can touch the wire to the engine block itself, a bolt screwed onto the engine block, the body or frame of the car near the temp. switch wire etc. There are many sources of a good grounding point. Make sure the ground you use is clean so you get a good connection.
Old May 7, 2005 | 06:29 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
I wouldnt get the hypertech switch. Go with the Jet fan switch. Comes on at 195 and cools to 185. Hypertech wants you to also get the chip too when you plug in the Hypertech fan switch.
Old May 7, 2005 | 07:59 PM
Bruticus's Avatar
Whats the website sounds like a good choice I think I will go with the Jet Fan Switch.
Old May 8, 2005 | 04:10 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
summit is where i got mine.
www.summitracing.com
Old May 9, 2005 | 06:39 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
i don't think you can go wrong with either fan switch
i'd also recommend installing a 180 stat, preferably one of the balnced sleeve/high flow ones
do both and you should be all set
Old May 9, 2005 | 09:25 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
yeah Don 79 TA is right, you should also install a 180 thermastat.. that will be perfect
Old May 11, 2005 | 01:51 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Correction here: if the fan does NOT come on with this procedure, you either have a break in the wiring, a bad relay, or a bad fan motor.. if the fan DOES come on, then you need a new fan switch...
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
sheachopper
Jul 31, 2019 11:27 AM
Quzyle
Oct 15, 2015 03:35 PM
tuningnewb
Sep 23, 2015 07:06 PM
