electric water pump mounting brackets?
Old Oct 6, 2005 | 03:14 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I have done a search on this topic and did not find the info I was looking for. I know a lot of people have asked this question and I am hoping this post will finally answer it.
I have a 1991 formula with the serpentine system. I have already ditched the smog pump and am going to get rid of the A/C this winter. I want to run an eletric water pump, alternator and ps pump only. The question is what do I need and which brackets/belts make it all work?
I am talking regularly available stuff, not March with their $500 setup.
I found these pics on this site of what I am trying to accomplish.
Thanks!
Old Oct 6, 2005 | 03:16 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
first pic
Old Oct 6, 2005 | 03:17 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
second pic
Old Oct 31, 2005 | 03:56 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
The powersteering bracket is a stock v belt bracket. You can buy the alt. bracket from summit. its like 70 bucks??? Not to totally sure. Then get some v belt pullies from a bone yard and your set. I have all aluminum ones on my car and I like that but if budget is what your looking for go junk yard shopping.
Old Nov 1, 2005 | 04:50 PM
91tpiTA's Avatar
Car: 91 T/A, 79 T/A
Engine: 305 TPI, '68 350 Olds SC'ed
Transmission: 700r4, 350 Streetfighter
Axle/Gears: stock, 3.42
Question about stock water pump, because I want to switch to elec. water pump too: how man GPH does the stock pump on a 305 TPI pump? And if I get one that pumps more per hour, is it bad or do I need to match GPH with the elec. pump?
Old Nov 1, 2005 | 11:48 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Well I am not sure on the rate that a stock pump puts out but it varies with engine speed. Lets say you have an electric water pump that flows 80 gallons per hour. And your stock pump flows from 20 gallons per hour to 130 gallons per hour. Your stock pump can out flow the electric depending on engine speed. Does that make sense. I know those figures are off but you get my point.
Old Nov 7, 2005 | 02:02 PM
w1964bgta's Avatar
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
gph
I think as long as your not WOT all the time they work just fine my buddy has one on 500'' mopar and it does quit well.
Old Nov 7, 2005 | 02:06 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I think there was a debate in an earlier thread about this. At freeway speed with about 2600 rpm's or more the mechanical pump moved more water. I cant remember. You can try searching it.
Old Nov 7, 2005 | 07:35 PM
w1964bgta's Avatar
elec water pump
But even at haghway speeds the electric pump still did the job?
Old Nov 7, 2005 | 07:43 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
It should.
Old Nov 9, 2005 | 09:08 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Hey Fastbird, I don't know if you've found what you need but alan grove has nice, inexpensive brackets for what you wanna do.
www.alangrovecomponents.com
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
