Best way to stop a leaking radiator?
Old Oct 6, 2005 | 03:47 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
I have a leak in my radiator and don't want to use the stop leak stuff cause i hear it can F up your heater core. Any one have any ideas on how to fix the leak? It is leaking from the side where the end seals to the metal fins.
Old Oct 6, 2005 | 05:34 PM
camarokev400's Avatar
go buy a new one for 100 bucks or so... they really arent that expensive at like advanced auto or auto zone.........
Old Oct 6, 2005 | 08:07 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
1.) Drain the rad
2.) Let it dry out (or use a heat gun/hair dryer to dry it)
3.) Clean all the corrosion lightly with something like a small brass wire brush on a drill/dremel
4.) Clean it with alcohol
5.) Apply JB Weld
6.) Let it cure for a full 24 hours
7.) Fill the rad & you're done.
I once fixed the low pressure side of an R134a mini-freezer with JB Weld. The stuff is still going strong after 2 years.
Old Oct 7, 2005 | 11:56 AM
trueburton's Avatar
thanks any other ideas?
Old Oct 7, 2005 | 01:20 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Most radiator repair shops could probably take care of that. Not sure how much.
I've seen the JB weld method used with varying success. We did the repair on a customers car, no compaints to date. Likewise, we've done it and within 20 days it was back to leaking. It's a real quick, easy fix, yes (by all means, try it).
Old Oct 8, 2005 | 03:25 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Best way would be to be a new radiator altogether, although this might not necessarily be the cheapest or easiest route.
Old Oct 8, 2005 | 05:37 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Replace it or have it repaired. No more than what one cost its better to replace it.
Old Oct 10, 2005 | 09:41 PM
trueburton's Avatar
I put a new one in for 120 and it works great.
Old Oct 10, 2005 | 09:44 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Cool Deal. Glad you got it fixed.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Bohemian
Aug 15, 2017 05:11 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
bamaboy0323
Sep 12, 2015 07:14 PM
