*sigh* weird idle issue when defroster/A/c system is on...
Subscribe
Oct 18, 2005 | 03:09 PM
Alright, heres the weirdness, any other setting But the max a/c and the defrost setting will not change my idle, BUT when the setting is on defrost/max A/c the idle sky rockets up to 3k on the tach! WTF is going on? anybody got any ideas?
Reply 0
Oct 20, 2005 | 01:58 PM
I can't really comment much on this, but I can say that the RPMs are supposed to jump up a bit when the A/C is on...but on mine it's onyl about 200 RPM. I don't recall if the heat is supposed to raise the revs at all.
Reply 0
Oct 20, 2005 | 02:18 PM
i know its supposed to jump up a little, But whats wierid is that only on max ac/Defrost the rpm's jump up from idle (around 650) to 3000 rpms and stays there, (in park) and in drive it goes from 800 to around 2500/3000 rpms and stays there, no other setting does it do this....
Reply 0
Nov 3, 2005 | 03:12 PM
Have you looked to make sure you have no vacum leaks? I believe the A/C, heater controls were still using vacum.
Reply 0
Nov 3, 2005 | 06:19 PM
On the 83 Berly all the heater controls are vacuum driven.. there are 3 vac diaphrams in the system
one on the passenger side near the kick panel, on by the center console, and just to the left of the heater box (right by the firewall, if you look at your radio you go straight back to the firewall and it is right there. If any of those has a leak it could cause that.... chances are it is the one that controls the doors for the MAX side. When I pulled my dash out to change the heater core. could also be the rubber hose going to it. (I did it all out because I had to fix the vac to the control so I would get more than defrost lol)
In fact even some new cars STILL use the vac system for the door control
Reply 0
Nov 4, 2005 | 10:30 AM
Do these cars have a throttle kicker? If so, could it be badly adjusted--guessing wildly.
JamesC
Reply 0
Nov 4, 2005 | 12:28 PM
I do not think so...
Reply 0
Nov 6, 2005 | 05:38 PM
my 86 had a kicker
Reply 0
Nov 7, 2005 | 12:04 PM
83 would be a carb with a kicker, have to be out of adjustment or the bracket is bent I'd think. Vacuum problem would make it run rough.
Reply 0
Nov 7, 2005 | 08:46 PM
Alright, wheres the kicker at? (and what would i be looking for? IE: Shape/location)
Reply 0
Nov 7, 2005 | 08:59 PM
Quote:
round cyliner about two inches long and one inch wide with a rod coming out of it and one wire going to it. It should be mounted right on the carb near the linkage, ill take a picture of mine tomorrow (to cold out now to go to the car port and uncover the car).
Reply 0
Nov 7, 2005 | 10:10 PM
Oh. that is not a kicker people. that is what you call a Dashpot..... no wonder i didn't know what the heck you all were talkin about... Yea. if the selenoid has enrgized and it is not adjusted properly it will leave you with a high idle that will not go down.. the Nice use for it is so you do not end up slaming the butterfly's shut on the carb causeing a little lurch until the engine sucks them open...
Reply 0
Nov 7, 2005 | 10:36 PM
All this is reminding me of the hidden track on a Korn CD where a man and a woman (presumably husband & wife) are arguing about all dashpots...
Reply 0
Nov 7, 2005 | 10:40 PM
Quote:
I think i know what you are talking about now, however if i am thinking about the same thing, i it affects my idle with out the max a/c \defrost on, perhaps im thinking of the idle adjustment screw? (if thats not what it is called then oh well, It does have ONE wire comming off the front of it, it is on the passanger side, heres a little text drawing to show you what im talking about)
_____
| | -------> Front of carb
(linages here)} <---------Idle speed screw/kicker/Dashpot?
Reply 0
Nov 7, 2005 | 10:42 PM
_____
electric choke?
Reply 0
Nov 7, 2005 | 10:44 PM
The choke is on the other side of the carb (drivers side) found that already
Reply 0
Nov 7, 2005 | 10:46 PM
hmm my choke is on the passenger side sigh
Reply 0
Nov 7, 2005 | 10:49 PM
you also have the quadracrap (assuming its the stock carb :P) I got the Veracrap (2bbl verson of the Quadracrap)
Reply 0
Nov 7, 2005 | 10:54 PM
ah i see i say we burn them have a bonfire then buy holley's
Reply 0
Nov 7, 2005 | 10:57 PM
I can get a Holley II :P yea, the bonfire idea sounds great, lets make sure the carbs have plenty of fuel in the fuel bowls
Reply 0
Nov 7, 2005 | 11:25 PM
hell ya lets pick a time and date im shure we can find a few others to join in!!! lol
Reply 0
Nov 8, 2005 | 05:48 AM
The manual, IIRC, calls the piece in question a throttle kicker solenoid, but again, IIRC, Summit or Jeg's calls it a dashpot. At any rate, check the following link for a pic of the Holley version (HYL-46-74):
http://store.summitracing.com/defaul...=egnsearch.asp
The idle screw sets curb idle speed; the kicker sets A/C idle speed (a 100 or 2 above curb idle to compensate for compressor drag). The solenoid doesn't have power enough to bump the idle up by itself. Once the driver has accelerated a bit with A/C on, however, the solenoid pops forward enough to keep idle speed up.
JamesC
Reply 0
Subscribe
