OIL COOLER LINES!!!
Old May 18, 2006 | 09:40 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
OIL COOLER LINES!!!
I AM PUTTING IN A STOCK OIL COOLER IN MY ROC AND NEED TO KNOW WHERE THEY HOOK UP IN THE ENGINE COMPARTMENT. ITS A 90 ROC, ANY HELP WOULD BE GREATLY APPRECIATED.
Old May 18, 2006 | 09:58 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Turn off caps locks. It's annoying to read.
An adapter at the oil filter is the most common place to attach a cooler. Something like this:
Old May 18, 2006 | 10:10 PM
90IROC1's Avatar
Car: 90 IROC-Z
Engine: LB9
Like I said in the first post I have a stock oil cooler set up I am going to hook up in the car. I know where it hooks up to he oil filter at. What I need to know is after it's hooked up at the filter and the stock steel lines run around the oil pan, where do you hook the rubber lines to????? The radiator the heater core???? Any one know.
Old May 18, 2006 | 10:13 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Originally Posted by 90IROC1
What I need to know is after it's hooked up at the filter and the stock steel lines run around the oil pan, where do you hook the rubber lines to?[extraneous question marks deleted]
Uh, the oil cooler?
Old May 18, 2006 | 10:18 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
MINE HAS ONE COOLANT LINE FEEDING THE COOLER OUT OF THE BLOCK AND RETURNING IT BACK IN THE HEATER RETURN LINE. SOME YEARS MAY BE DIFFERENT. BASICALLY ONE COOLANT LINE IN, ONE LINE OUT.
All caps is very annoying!!
Old May 19, 2006 | 12:30 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Originally Posted by 305q_ta86
Uh, the oil cooler?
Old May 19, 2006 | 12:42 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
The metal oil cooler line nearest the front of the car goes via rubber hose to the radiator just below the filler cap.
The other metal line goes via rubber hose to a metal and then rubber hose that connects onto the heater core. That same metal line also branches off to a plastic control valve that's got a vaccum line on it. I think it's a heater control valve (near the front of the engine, passinger side).
Old May 27, 2006 | 08:38 AM
Genesis98's Avatar
Car: 88 Camaro SC
Engine: 2.8 ->305->350
Pics?
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
