what temp is normal
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
what temp is normal
what do most third gens run at? we have been getting some very hot humid weather recently 92+ outside temp. my car runs a little over 220 constantly. i was driving on the expressway with the A/C on. car is not overheating but runs much warmer than what is usually runs at. car runs almost to the line between 220 and 260, but it didnt excede that line. i watched the temp gauge closely. my car doesnt have an airdam. did all camaros come with airdams, i have an RS 305 TBI and my car doesnt have one. did it come like that new or did a prevous owner take it off? car doesnt approach overheating temps and i watch the guage closely. its proabaly normal for the car to run a little higher than normal considering the A/C is being run and the outside temps are quite high. is it safe to run it at these temps as long as it doesnt approach red? i recently replaced upper and lower radiator hoses and i changed the collant.
Car: 1989 camaro rs
Engine: 305 tbi
Originally Posted by thirdgen88
put the airdam back on, it needs to be there (and should be)...
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
My car didnt have one until about a month ago. It ran about 1/8" before the 220 line at all times no matter what, and when I put the air dam on I noticed no difference in temperature. This is probably due to the fact that my fan is hot wired to be on at all times. You can do this by grounding the green wire that goes into the fan relay, its on a little clip that screws into the firewall above the brake booster. It should have a large black wire, a large red wire, a small black wire, and a small green wire going into it. Dont pull it out of the fan relay, just splice it somehow and ground it to the chassis.
However, I would recomend that you get an air damn. Its not necessarily good for the fan to be on at all times and things should be set up the way they were intended to be. I paid $30 shipped for a brand new GM replacement off ebay. I didnt have bolts, but if you look under there you will see what you need to mount it. Regular old small nuts/bolts/washers that you probably have kicking around the garage anyway. If not you could go to a hardware store and piece together the hardware for less than a couple bucks.
I just did a quick search, you may be able to find something better if you search harder. However if you dont have one I must say its worth it. You will probably scrape it on everything but its pretty resilient.
eBay Motors: 85-92 CAMARO Z28 RS IROC AIR DAM NEW GM 86 87 88 89 90 (item 280011552378 end time Aug-24-06 18:34:16 PDT)
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
You should be able to purchase a brand new air dam from the GM dealer for around $25-30+ dollars. Just do it.
Otherwise, the General designed the 3rd gens to operate at about 220 for emmision compliance. You can install a lower activating temp fan switch to help keep it cooler. Do a search... there's a lot of info on this topic.
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
im a firm believer in the 180 t-stat and water wetter, along with the stock air-dam of course, it works VERY well, im using an aprox 35% coolant 65% water mixture, with a bottle of that redline water wetter stuff and a 180 t-stat... today on 295 i was cruising at my usual 70-75mph, with the windows up and AC on and the temp gauge was about a 3/4's of a line before halfway, i thought that was a big surprise lol but when im sitting in traffic in 95 degree weather with 80% humidity (today in NJ) it gets up to the normal 220.... i guess we will see how long these good temps last, anyone else like this stuff?....
Car: 1989 camaro rs
Engine: 305 tbi
called gillogly chevrolet
called a local chevy dealer today. they told me there is a replacement baffel aviable. my car already has a piece that forces air from the two holes in the front of the bumper. is that the airdam, i thought there was something else on my stepfathers '84 z28. he still has his car but its been completely apart for the last few years. he's doing a t56/ TPI engine swap and his car is completely apart so i cant look at it for comparison purposes.
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
the air dam looks like this
eBay Motors: 82-92 New GM Camaro Lower Radiator Air Dam Deflector (item 200012944652 end time Aug-07-06 09:41:55 PDT)
mounts under the car and is mounted right by the rad
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
I bought the same part from the same people. I would recomend buying this very piece.
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
awesome, get that baby on there it helps alot! lol keep your motor cool in this ridiculously hot summer....
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
i got an air dam from hawks and took the stat out...100 degree days on the highway and it sits at 160. around town...maybe 190.
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: what temp is normal
Help!! I am getting conflicting info about the upper air baffle/air dam in an `88 Iroc. Bruce at Hawksthirdgen tells me it is ok to remove it, removing it will not cause the car to overheat. What is going on? Most everything I have read on this site tells me that the air dam is mandatory for cooling.
Linson
Oct 1, 2015 09:50 PM
