Fan not turning on, even with A/C
Old Aug 24, 2006 | 09:19 PM
Iron_Maiden's Avatar
Car: 90 Iroc
Engine: L98 TPI
Axle/Gears: 3.23s
Ahh...my cars been overheating when stopped or at slow speeds. My dad and I were looking at it and come to find out the fan isnt turning on at all, even when the ac is on. I checked the fan and it works when wired to a power source so I know its not the fan. Whats the problem here guys??
Old Aug 24, 2006 | 09:31 PM
j dezzy's Avatar
Car: 87 TA
check your fuse and/or relay...
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
what are you bypassing when hooking direct power to the fan?
Old Aug 25, 2006 | 04:47 PM
Car: 90 Iroc
Engine: L98 TPI
Axle/Gears: 3.23s
I just hooked up the fan to another battery with some wires i had laying around and it worked
Old Aug 25, 2006 | 05:03 PM
raptor80dad's Avatar
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
Old Aug 27, 2006 | 02:32 PM
MJH91RS's Avatar
Car: 91Camaro RS
Engine: 305TBI
Transmission: 5-Speed
Axle/Gears: 3.08
My car did the same thing, ended up being the fan switch.
Old Sep 8, 2007 | 12:04 PM
camaro88sc's Avatar
Car: 1988 Chevy Camaro SC
Engine: 305 TBI
Re: Fan not turning on, even with A/C
Hey guys sorry to bring back an old thread, but i figured why start a new one. Well I have the same exact problem as Iron_Maiden did. I actually even tried the same things he did, mine has been doing it for a while now. When i first got the car i could turn the ac controls to defog and it would turn my fan on, but then the next summer that stopped working. But then the bi level control would turn the fan on, but now that stoped and none of the other controls are working to turn it on. So basically im now in the same boat as Iron_Maiden. So i read the responces people wrote for him and now my questions are, which fuse do i check?, where is the relay located that they speak of?, and where is the fan switch?
I greatly appreciate the help, thanks guys
Old Sep 8, 2007 | 01:19 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Fan switch in passenger side head below #5 and #7 plugs. Grounding the switch lead with ignition in 'run' should engage the fan. If this doesn't work you can trace this lead to the relay (make sure you've got the right one with a continuity check). Make sure you've got power in and power out when the control wire (wire to switch) is grounded, ignition in 'run', of course.
RazorN8
Jan 7, 2022 11:44 AM
evilstuie
Jan 9, 2020 08:29 PM
Papaginos
Sep 27, 2015 03:29 PM
BikeFarm
Aug 11, 2015 11:35 PM
