cooling problem...
Old Mar 12, 2007 | 10:37 AM
chingon88cam's Avatar
Car: 92 RS
Engine: 5.0 L03
cooling problem...
my car's fan doesn't come on 'till its almost hits the red part of the temp. gauge. I have to turn the AC on just to keep it cool in traffic, i do have a 180* t-stat (drilled), but even before i drilled it i recall the fan behaving the same way. Is there anyway i can reset the fan temp sensor??
any suggestions will be great help, thanx!!!!
Old Mar 13, 2007 | 03:40 PM
Grim'91Z's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7L V8
Transmission: 700R4 Auto
Just buy a new one at Summit.
Old Mar 13, 2007 | 03:51 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I'd first verify the accuracy of the temp guage you're using. The stock guages are not always a good indicator of the true temp. You can, however, get a fan switch with a lower than stock setting.
Old Mar 13, 2007 | 10:38 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
yeah i never trust OEM guages i keep the dash stock exept for the Speco Tach but i have 3 guages screwed to my firewall in my engine bay that is water temp, oil preshure and oil temp.
Just to add my OEM temp guage hits 260'F when the After market one reads 235'F, The OEM guages are just a guide they are a cheap, mass produced item. A good example is the Third Gen OEM Y pipe, It workes but how well is a different story.
Old Mar 14, 2007 | 01:04 AM
Grim'91Z's Avatar
Engine: L98 5.7L V8
I think the fuel gauges are GM's worse. Both the Silverado and Camaro read toward the full side on take off and the empty side when braking.
Old Mar 14, 2007 | 01:22 AM
charliehaley's Avatar
Car: 87 Camaro Sport Coupe
Engine: 305 CARB
Transmission: th700r
Axle/Gears: stock 2.73 open
If the car is overheating you use the heater not the A/C. The A/C just makes things worse.
Old Mar 14, 2007 | 01:39 AM
Engine: 305 CARB
Old Mar 15, 2007 | 07:31 PM
VenomX-87's Avatar
LOL yeah my T.A is the same, First time i saw it happen i freaked coz i had just got the car put $30 in the tank took off and when i was slowing down it was on E im like "WTF this has one major fuel leak" but nup just a real bad surge problem.
Old Mar 15, 2007 | 07:37 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
whenn i first got my car i thought i had a leak its my first car
Old Mar 16, 2007 | 07:52 AM
TIE1-ON's Avatar
Car: '92 Z/28
Engine: 355 HSR, Hooker LTs, Dynomax X
Yes, do not trust the OEM gauge. Junk.
Old Mar 16, 2007 | 10:22 AM
Car: 92 RS
Engine: 5.0 L03
the heater does help, but when you're stuck in traffic on 85* weather, the last thing you want is more heatt. I have tried the heater and it doesn't do as wwell when you're in stop and go traffic for 45 minutes
My mom has a new tahoe, and the fuel gauge still does that, even escalades do it.
GM just suck when it comes to fuel gauges.
Old Mar 19, 2007 | 01:59 AM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
not on a L03! AC makes the fan come on automatically
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
64goatman
Sep 9, 2015 01:09 PM
