Fan Fusible Link
Old Mar 20, 2007 | 11:49 AM
Detroit_Z28's Avatar
Car: 91 Z28
Engine: L98 350
Transmission: TH350
Fan Fusible Link
Hi all-
In the process of installing a new motor somehow the trans cooler line got bent into the passenger side fan, jamming it and I didn't notice. I could hear one fan (probably driver's) working, up until yesterday when it failed and overheated.
I jumped the relay, and nothing happened. I used my volt meter to check the power lead going into the relay (orange wire), and I've got nothing going to the relay. My service manual says theres a fusible link somewhere - anybody know where?
Old Mar 20, 2007 | 12:04 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Fan Fusible Link
Usually they're near the battery area and starter.
Old Mar 20, 2007 | 12:09 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
The fuseable link for my 89 Bird is by the battery.
Old Mar 20, 2007 | 12:13 PM
Car: 91 Z28
Engine: L98 350
Transmission: TH350
Thanks for responding-
Is it the wire with a standard "blade" style fuse in it? I see one of those by the battery and the fuse looks OK. I was thinking there was an old style wire-type fusible link the manual was referring to
Old Mar 20, 2007 | 12:41 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
The fan fusible link is by the battery. The blade fuse is for the fuel pump.
Old Mar 20, 2007 | 03:04 PM
Car: 91 Z28
Engine: L98 350
Transmission: TH350
Ok, thanks alot, I'll check it out tonight!
gta892000
Aug 11, 2019 11:16 AM
gta892000
Sep 16, 2015 12:40 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
383cam
Sep 9, 2015 06:01 AM
