A/C clutch question
Old Apr 10, 2007 | 11:38 PM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
A/C clutch question
Please someone tell me that my A/C clutch is not supposed to be constantly turning on and off! I'm almost certain that they turn on once and turn off whenever you shut the a/c off or the car off.
I've noticed this recently and it probably explains why the semi-constant adding of freon.
Old Apr 10, 2007 | 11:43 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: A/C clutch question
it will go on and off if you are using the a/c. but with the a/c off it should not be going on and off. if the a/c pump is bad i have one that i will sell you. just let me know
Old Apr 10, 2007 | 11:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The compressor will cycle when necessary while either the A/C or defroster are on. Regardless, if you're losing freon it's because you have a leak.
Old Apr 11, 2007 | 06:12 PM
Guro 305's Avatar
Axle/Gears: Stock
It kicks on every few seconds or so with the a/c on. I was certain that it only kicked on one time and that's it but I guess I could be wrong.
It definitly has a leak somewhere but I can't find it. It sounds like the leak is coming from the compressor itself since I find what appears to be residue around the clutch and houses in front that smells like, well, freon. I don't see anything wrong with the hoses so can compressors actually leak through the clutch area?
Old Apr 12, 2007 | 12:09 AM
not sure if they can leak, but like i said i have one i can sell you, work great when i took it off.
Old Apr 12, 2007 | 09:30 PM
Guro 305's Avatar
Axle/Gears: Stock
The clutch or the whole compressor?
Old Apr 12, 2007 | 11:47 PM
if your intesetd let me know. i could get a pic of it for you if you want me to
Old Apr 14, 2007 | 11:32 PM
T/Aballspackage's Avatar
Before you change the compressor try this. If you can get ahold of a refrigerant recovery machine recover and evacuate the system and inject dye into the system. You can get the dye at any auto parts store. Recharge the system with the dye in it and just run the vehicle for about 3 or 4 days. After that check your fittings, connections, and lines to see if any came out. The flourescent dyes will require a black light to see it. Thats about the easiest way other than spraying the system with a soapy solution and looking for bubbles with the system running. And as far as the clutch turning on and off it is supposed to do that about 2-4 times per minute. If it exceeds this, the system probably needs to be recharged.
Old Apr 15, 2007 | 10:33 PM
Guro 305's Avatar
Axle/Gears: Stock
Did it come from a V8 and do you have the hoses that attach from the compressor to the bottle?
Old Apr 15, 2007 | 11:03 PM
yes it cam from the 305 5L v8. sorry i don't have the hoses, those are long gone
Old Apr 17, 2007 | 09:36 PM
Guro 305's Avatar
Axle/Gears: Stock
Let me see what I can find at the salvage yard this weekend and I'll let you know.
Frozer!!!
Jan 19, 2024 04:55 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
rsrmoore
Aug 7, 2015 08:44 PM
