long short water pump?
Old Jun 2, 2007 | 04:30 PM
FF400's Avatar
Car: formula
Engine: 400 sbc
what's the difference between short and long nose water pumps?
i've never been told nor seen them side by side to know the difference.
if i took a guess it'd be the lenght from the block to the end of the pulley. am i correct?
my 1975 400 would most likelly have a long style water pump..?
i'll be mesuring so as soon as i get an answer i can go order one..
p.s. it's almost finally complete... again!
Old Jun 3, 2007 | 01:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: long short water pump?
Yes, it's the height from the block to the end of the pulley. Either pump will bolt to any engine, but the pump has to match the accessory mounting setup you're using.
Old Jun 3, 2007 | 02:52 PM
lincolnpark773's Avatar
Originally the short pumps where for Vettes', they're three inches shorter. The same applies to big blocks, this makes it possible to put a big block in place of your small block and have the fan in the same spot.
Old Jun 3, 2007 | 11:13 PM
FF400's Avatar
Car: formula
Engine: 400 sbc
tnx!
Old Jun 3, 2007 | 11:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not just Corvettes. They were for every car until 1969, and were still used on trucks and Corvettes for quite a few years after that.
Old Jun 17, 2007 | 12:37 PM
Not true my 68 camaro w/327 came with a long pump.
Old Jun 17, 2007 | 03:51 PM
357mag's Avatar
Car: 94 C1500
Transmission: NV-4500
Axle/Gears: 3:42 10 bolt 8.5"
The long pumps came into being when the accessories started being mounted to the front of the cylinder heads. The short-pump engines used the outboard style brackets, so the accessories could actually fit behind the leading edge of the heads.
Tim sends
Old Jun 23, 2007 | 01:56 AM
fastcar06's Avatar
Car: 1991 pro street formula
Engine: 355
Transmission: turbo 350 w/ 3200 stall
Axle/Gears: 9" ford detroit locker w/ 456
my 67 camaro's both had short pumps on them. 350 and 327
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
MoJoe
Sep 24, 2015 09:12 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
