Looking for replacement electric fan ideas??
Old Jun 25, 2007 | 10:34 PM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Hey guyz looking for a electric replacement fan on my 89 rs 305 TBI with single elec fan...any ideas? or cfm specs?
Old Jun 26, 2007 | 01:51 AM
ReverendZ28's Avatar
Car: 1988 Z28
Engine: 350ci
Axle/Gears: Stock
Re: Looking for replacement electric fan ideas??
I got the same application needs 88 tbi single stock fan. lookin to change that real quick.
Old Jun 26, 2007 | 03:33 PM
Axle/Gears: Stock
you saying i need the 88 elec fan? I was looking at the flexalite fans is 3300 cfm any good?
Old Jun 27, 2007 | 05:49 PM
Axle/Gears: Stock
BUMP!! NEED HELP!
Old Jun 30, 2007 | 09:12 PM
Iroc355l98's Avatar
Use the ford taurus dual speed single fan. Got mine from work cost me like 65$ with my discount and outflows most aftermarket fans mods are minimal. But I went all out using a volvo 2spd fan relay and a bunch of fancy stuff car never gets over 150* with the fan running on low
Old Jul 2, 2007 | 04:41 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
I just ordered a PermaCool fan # 771-19008 that pulls 3000cfm, the highest I have found. I am only replacing the primary at this time, it looks like the original. After I install it I am driving out to the desert to see how well it cools.
Old Jul 2, 2007 | 06:52 PM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
What were your temps getting up to and when (stopped/low speeds and highway speeds) before the switch?
Old Jul 9, 2007 | 11:19 AM
camar0rs's Avatar
i just ordered the permacool fan as well so we will see how it works in FL
currently having overheating issue with AC on only
im changing to high flow water pump, changing intake gaskets (seems like a front leak of coolant) and upgrading 1 of the fans...
will post results within 2 weeks
Old Jul 10, 2007 | 06:10 PM
Axle/Gears: Stock
k thanks
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
