pusher vs. puller
Old Aug 15, 2007 | 08:03 PM
schmeck11's Avatar
Car: 82 TA
Engine: 305 swap 350 swap 383
Transmission: 2004r
Axle/Gears: 3:73
pusher vs. puller
what is the difference or I should say advantages of pusher vs. puller electric fans?
Old Aug 15, 2007 | 08:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: pusher vs. puller
Pullers are more effective at cooling the rad. Pushers are easier to fit in some configurations.
Old Aug 15, 2007 | 09:21 PM
schmeck11's Avatar
Car: 82 TA
Transmission: 2004r
Axle/Gears: 3:73
then maybe you can tell me if this is ok. I bought, what I though (and was told) was a pusher, tonight I got it hooked up and it's a puller. I have it mounted on the engine side of the radiator, so it pulls air through the radiator and blows on the motor. is this a good set up? they work great, I just want to make sure i'm getting the more effective cooling kind of fans. thanks
Old Aug 15, 2007 | 09:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's the preferred way to do it.
If you switched the wires around, it would be a pusher.
Old Aug 15, 2007 | 09:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if the fan is mounted of the motor side of the radiator, it should be pulling through the radiator and towards the motor, it should never be blowing towards the front of the car.
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
You have it hooked up the way the factory did it.
Old Aug 15, 2007 | 09:28 PM
schmeck11's Avatar
Car: 82 TA
Transmission: 2004r
Axle/Gears: 3:73
well that's good news, if that's the case I'll leave it alone, thanks for the imput!
Old Aug 15, 2007 | 10:02 PM
schmeck11's Avatar
Car: 82 TA
Transmission: 2004r
Axle/Gears: 3:73
stock was a mechanical (82 ta), I mounted aftermarket duals. I did get it right then, engine side pulling air towards motor, thanks guys
Old Aug 16, 2007 | 06:42 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Schmeck11, what did you use for fans/shroud? Thanks
Old Aug 16, 2007 | 06:50 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
I bought two fans and radiator off ebay. The guy had them set up as pullers but it was wired as a pusher. He said he had troubles over heating. Wonder why... Anyway, I called the fan manufacturer and they told be to also remove the fans from the motors and reverse them also. Works great now.
Old Aug 16, 2007 | 08:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
some fans have uni-directional fan blades. While yes, you can just flip=flop the wires to make it run backwards, the fan blades work best spinning in one certain direction.
some fans the blades are symmetrical and all you have to do is swap the wires
Old Aug 16, 2007 | 08:57 PM
schmeck11's Avatar
Car: 82 TA
Transmission: 2004r
Axle/Gears: 3:73
jimdutro vbmenu_register("postmenu_3434947", true); - I bought dual 11" Spal fans off ebay, I think it was auto wizard out of florida. as for shroud they had the shroud built around them, just a matter of mounting them, (you had to figure that out yourself).
Old Aug 16, 2007 | 09:14 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
schmeck11, thank you for the info. I appreciate the quick reply.
3.8TransAM
Sep 17, 2015 02:16 PM
theshackle
Aug 22, 2015 06:52 PM
Jester
May 28, 2001 08:52 PM
Quiet Bob
Mar 14, 2001 05:31 PM
JOEMAROZZ4
Feb 14, 2001 10:59 AM
