a/c compressor -to remove or not?
Old Mar 31, 2008 | 04:51 PM
ukz28-5.7's Avatar
Car: 92 z28
Engine: 5.7
Transmission: auto
I have removed all of my a/c system on my 92 5.7 camaro,but left the compressor.
Will I need to replace with a pulley ,/a/c delete pulley ,or can I leave the compressor on the auxillary belt drive? Will it seize up?
Old Mar 31, 2008 | 10:34 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Re: a/c compressor -to remove or not?
You can leave it on there it will be fine.The only reason to remove it,is if you want to clean up the engine bay.
Old Apr 1, 2008 | 10:36 AM
ukz28-5.7's Avatar
Car: 92 z28
Engine: 5.7
Transmission: auto
ok thanks
Old Apr 2, 2008 | 03:58 PM
iansmusical's Avatar
Car: 91 Firebird & 02 VW Polo TDI
Engine: 3.1 V6 & 1.4 3 cylinder
Transmission: Auto, M5
Axle/Gears: Stock
Hi,
Funnily I noticed a sticker near the headlight on my 91 V6 Firebird that showed the belt path needed with and without the A/C compressor, if that helps you?
Ian
Old Apr 3, 2008 | 08:56 PM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
remove it, and get the delete pulley off ebay for liek 20 bux... relocate yoru battery to the hatch too, just those 2 mods alone will help your traction significantly
Old Apr 4, 2008 | 09:36 AM
eddie jr's Avatar
if it still worked and you may want it in the future or to sell it, remove it. With it open to air and moisture, the hot/cold it will be exposed to continuously (from the engine) will not make it fair well.
Old Apr 4, 2008 | 11:21 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Remove it and get the ac delete pully. Smart move on deleting the ac, less weight, less clutter (most importantly more hand room!!) and frees up some hp.
Old Aug 10, 2010 | 07:00 PM
CamaroIROC88350's Avatar
I am trying to get my a.c. compressor off of my car but there are 3 bolts behind it that I can't get off with any of my sockets/wrenches.
It seems like a 5/8 socket would do the trick but either that doesn't fit or the socket isn't grasping ahold of the bolt's head for me to turn it.
Does anyone know the correct size or another way to get these bolts off so I can install my a.c. delete pulley?
I've tried all of the sizes just for craps and giggles and nothing worked so far.
Thanks.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
my86bird
Oct 23, 2015 12:20 PM
85Special
Sep 3, 2015 04:21 PM
mrdevontay
Sep 2, 2015 08:04 PM
