boiling over?
Old Apr 16, 2008 | 01:04 PM
ally0ucan3at's Avatar
boiling over?
HEy all welll i not that mechanical friendly so ill take all the help i can get heres the prb my cammaro RS 91 Auto has a v8 383, i keeps over heating after about 20 miles of driving, there are no leaks at all , i am thinking its the thermo stat .... it was really bad lst night all my anti freeze boiled into my radiator fluid catch tank and was steaming and wistling like crazy, if it is the t-stat can some one please tell me how to replace such a part and where it is located i really appriate it...
Thanx
-Henry
Old Apr 16, 2008 | 05:41 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Re: boiling over?
Had a similar problem, it was the fan switch. My fan wouldent run at all. I dont know how to do it, but I had a shop fix it [the fan always runs now so it stays real cool] and it was only like 30$ for them to do it.
Old Apr 16, 2008 | 06:51 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: boiling over?
the termostat is located at the driver side in the front of the intake manifold. Follow the top radiator hose back to the motor and thats the housing it sits in. Depending on the intake style and configuration you may have to remove the throttlebody to access it. Also I'm assuming that you purchased the car modified by its previous owner. What exactly is done to it?
Old Apr 17, 2008 | 07:37 AM
Re: boiling over?
ummm all i had to remove was the air filter...and its housing
Old Apr 17, 2008 | 08:09 AM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: boiling over?
Was it in real bad condition or something?
Old Apr 17, 2008 | 08:46 AM
Re: boiling over?
well when i took out the thermostat i thought is was good, but when i went to auto zone and compaired it with a rnew one i realised how loose my t-stast was, and to check the water pump i just disconnected the tstat and the hose and left the hole open and turned on my engine and no water or liquid was even flowing in my engine, my buddy who is really goood with that **** said that coolant and water should have shot everwhere,so hopefulyl wheni get this new water pump and t-stat in everything will be back to normal, also check the pump by squeezong the hose and there was no pressure back when i let go , and i know that is a shure way of telling if the pump is bad anyone have any input to all this?
Old Apr 17, 2008 | 11:38 AM
WIll36's Avatar
Engine: 355, 408
Re: boiling over?
Yes if the hoses are soft while the motor is running the water pump is toast. I'm assuming your car has a carb or TBI setup then if you didn't have to remove the TB that is on a TPI only setup I only mentioned that because if it was the case you would need the TB gasket to complete the job.
Old Apr 19, 2008 | 08:56 AM
Re: boiling over?
ok well just an update i rplace the water pump and thermostat and now there is no problems at all, i took of the radiator cap while the engine was running and there was plenty of water flow nice and happy now :-) thanks for the help guys
Bubbajones_ya
Jul 6, 2024 08:32 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
84redta
Sep 19, 2015 09:58 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
mustangman65_79
Sep 1, 2015 03:51 PM
