Charging with R12 and STB
Old Jun 15, 2008 | 10:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Will I need to remove the STB to have the AC charged--that is the charging port, correct?--or is there enough room between the port and the STB? There're other angles in my Car Details below.
JamesC
Old Jun 15, 2008 | 11:21 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Charging with R12 and STB
I just had my A/C checked and my STB was never a problem even when it was converted to R134.
Old Jun 15, 2008 | 03:17 PM
JamesC's Avatar
The 3-pt "appears" to run a bit closer to the port, but I'm probably just obsessing as usual. Thanks for the response, DJP.
JamesC
Old Jun 16, 2008 | 10:13 AM
eddie jr's Avatar
JamesC
James, yes that is the port they charge through (low side). iT is hard to tell in the pic but there may not be enough room, especially if they don't have 90* fittings on the end of their hoses (which they often don't for R12).
Old Jun 16, 2008 | 10:29 AM
JamesC's Avatar
Took the car in this morning (and it's already finished). No problems with interference.
JamesC
Old Jun 16, 2008 | 10:47 AM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Where in lawrence did you take it? I am looking to have some r-12 evacuated so I can replace an accumulator, but plan on putting r-12 in it again. All the shops here only service 134A now so I can't get serviced.
Cheers!!!
Old Jun 16, 2008 | 11:25 AM
JamesC's Avatar
Lawrence Automotive Diagnostics
2854 Four Wheel Drive
Phone: 785 842-8665
Four Wheel Drive is west off Iowa a couple of blocks on 31st.
They replaced the AC pressure cycling switch (which was broken and allowing the R12 to escape) and charged the system for $165.33.
So far I'm very impressed with the shop--enough so that I'll take my cars back to them.
JamesC
Old Jun 16, 2008 | 11:12 PM
Car: 83 z28
Thank you my friend. Be it if I have to visit my parents to get my r-12 evacuated than so be. besides, I was wanting to get a mini GTG up there for third gen's anyway.
Cheers!!!
Old Jun 18, 2008 | 09:34 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Whew, that's a tight squeeze. I'd think getting the threads on would work. I just wonder if the hose would be pinched trying to get the refrigerant through.
Old Jun 19, 2008 | 06:40 AM
JamesC's Avatar
Apparently, there was no problem. Car's been running COLD. The switch that I mention above, I suspect, has been at the root of a long battle with my AC, both 12 and 138. How a reputable garage could have missed the leak I'm unsure.
JamesC
Falcon50
Aug 22, 2020 03:26 PM
apie2546
Oct 16, 2016 02:24 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
