is stock enough?
Old Apr 28, 2009 | 11:02 PM
poomwah's Avatar
is stock enough?
I have an 87 gta minus engine... I got a hold of a 76 350 thats been bored .60 over. plans are to carb it. I have the factory radiator and the fatory dual electric fans. I've been told that theres NO way that the stock cooling system is going to keep the engine cool. I was thinking of opening up the rear vents on the 4 vent hood to let some heat out.
Is it true that the stock radiator and fans won't be enough?
Old May 5, 2009 | 05:43 AM
GadeXTrigger's Avatar
Car: 91 Camaro
Engine: 5.7Fl V8 350 tpi
Transmission: 700R4 Automatic
Re: is stock enough?
i would personally sell the dual fans and buy one mechanical one so it's always on but the thing is it will drain like 5 HP from your engine but if you got a mechanical one i don't see why it wont
Old May 5, 2009 | 07:34 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
As long as the stock radiator and fans are in good condition I don't see why it wouldn't keep cool. Why do you think it's going to get so hot?
Old May 5, 2009 | 07:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Just an observation: I swapped in dual electrics (which both turn on with head temp and/or AC) in my 350/330 and I've never experienced overheating--in fact, the engine runs cooler now than it did with the old 305.
JamesC
Old May 5, 2009 | 10:34 AM
oil pan 4's Avatar
Car: 89 Firebird
Stock is a relative term.
Is it a stock 2 core alumium or stock 3 core copper/brass?
I run a 3 core and a stock single electirc fan and a 12'' pusher fan on my z28 and it is more than enough in stop and go traffic. But I made a custom fan shrowd that mates the stock fan to the radiator. You know how there is about a 1.5 inch gap between the fan to the radiator in the factory set up, my car does not have that.
Old May 5, 2009 | 11:34 AM
87350IROC's Avatar
Car: 87' IROC
Stock dual electric will work fine. Many of us run 350s or bigger with it. You many want to use a different fan switch to turn on the second fan sooner.
Old May 5, 2009 | 01:46 PM
poomwah's Avatar
I was thinking of running them both constantly
Old May 5, 2009 | 02:07 PM
87350IROC's Avatar
Car: 87' IROC
You can do that but it will take forever for your engine to get warm. It'll also be hard on your fans, charging system, starting system. I'd recommend getting a fan control system, whether its stock or otherwise. I went with a Dakota Digital PAC-2000 setup.
Old May 5, 2009 | 03:35 PM
poomwah's Avatar
thank you 87 :]
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
