dam!!!!!!!!!
Old Jun 27, 2009 | 11:19 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
dam!!!!!!!!!
can anyone post a picture of what a fully operational airdam looks like on trans am ? , because my airdam slightly bends back .
Old Jun 28, 2009 | 09:12 AM
one92rs's Avatar
Car: SOLD!!!!!
Re: dam!!!!!!!!!
imho these are the backbone to the whole cooling system. if it is bent back in any way--REPLACE IT--. it is a cheap insurance piece.
Old Jun 28, 2009 | 12:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: dam!!!!!!!!!
they are usually bent slightly forward. If its back, you need to try to fix it or replace it.
Old Jun 28, 2009 | 03:14 PM
Re: dam!!!!!!!!!
all the mounting bolts are in place , its not bent back all the way it looks something like this )
Old Jun 28, 2009 | 05:17 PM
shouldahadav8's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 350 4bbl
Transmission: Stock Auto
Axle/Gears: Stock
Re: dam!!!!!!!!!
yeah could someone post a pick of what the air dam is supposed to look like?
this is mine, is it wrong? do i need to replace it?
Old Jun 28, 2009 | 05:45 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: dam!!!!!!!!!
yes you need to peplace it. they are angled slightly forward when right.
Old Jun 28, 2009 | 05:54 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: dam!!!!!!!!!
I made my own out of some polished alumminum and made about a 120* bend so its angled forward. Really forces air through the rad. now!
Old Jun 28, 2009 | 05:59 PM
Re: dam!!!!!!!!!
yup, thats pretty much what mine looks like , is it supposed to be scooping forward and not backward or whaa? im confused
Old Jun 28, 2009 | 06:04 PM
Stephen's Avatar
Car: 87 GTA
Re: dam!!!!!!!!!
Looks like somebody removed it at one point, then put it on backwards.
You could try flipping it, side to side.
Old Jun 28, 2009 | 06:05 PM
Re: dam!!!!!!!!!
ok , quick question , IF my airdam isn't working properly then why when overheating , i turn on heater full blast then temp drop by few degrees i.e 220 to 190?
Old Jun 28, 2009 | 07:20 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: dam!!!!!!!!!
because your heater core is a mini rad and the fan cools it
Old Jun 28, 2009 | 11:55 PM
Re: dam!!!!!!!!!
oh , cool , didnt know that , thanks for the info
Old Jun 29, 2009 | 12:47 AM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
Re: dam!!!!!!!!!
did the same thing could see a slite difference and its easy to make
Old Jun 29, 2009 | 09:27 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Re: dam!!!!!!!!!
Yea comparing the one i made to not running one at all made a HUGE difference!
Old Jun 29, 2009 | 09:54 AM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Re: dam!!!!!!!!!
If the air dam isnt damaged, just bent, try removing it, pouring boiling water over it, and then bending it back into the correct shape. Its just plastic and can be molded a little bit (If any of you ever played sports, its the same thing you did with your mouthguard to help fit it to your mouth)
Old Jun 29, 2009 | 10:00 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Re: dam!!!!!!!!!
Yea except the mouthgaurd would burn my mouth cause i had it in boiling water and didn't let it cool
Old Jun 30, 2009 | 03:00 PM
Engine: 350 4bbl
Axle/Gears: Stock
Re: dam!!!!!!!!!
could someone post a pic of a custom-built air dam? i'm looking to replace mine with one that i can build myself, i just need to know how
if someone could show/tell me how they did it, i'd be forever in your debt
Old Jul 2, 2009 | 02:25 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Re: dam!!!!!!!!!
i agree ^^^^
Old Jul 9, 2009 | 02:03 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: dam!!!!!!!!!
Here's a link to a thread on a fabbed one: https://www.thirdgen.org/forums/cool...their-own.html
1992Z28!
Nov 19, 2015 07:33 AM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
krisner89
Oct 10, 2015 06:03 AM
tommy z-28
Oct 6, 2015 10:58 PM
steimel94
Sep 23, 2015 12:48 AM
