Fans stopped working
Old Jul 3, 2009 | 08:12 PM
unknown459's Avatar
Car: 1992 Z28 Vert
Engine: 5.0
Transmission: 5 Speed
Just bought a 91 Z28 5.7 and the AC went out. So I fixed that now the Fans don't turn on. I checked the fuses they are all good. Any Ideas?
Old Jul 3, 2009 | 10:08 PM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
Re: Fans stopped working
Have you checked the relays? There should be relays for the fan on the drivers side firewall just to the right of the brake master cylinder. If you have the A/C on the fan should run constantly.
Old Jul 3, 2009 | 10:29 PM
unknown459's Avatar
Car: 1992 Z28 Vert
Engine: 5.0
Ok I will replace them thanks for the info.
Old Jul 3, 2009 | 10:34 PM
86irocu's Avatar
Car: 1986 Iroc-Z
you dont really have to replace them, there are ways of testing them. You can use a test light to test them. Im not sure about your car, but my car had one more relay that you should check by the passenger side front. Should be on the same wiring for the fan.
Old Jul 3, 2009 | 10:54 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Check my sig.
Old Jul 4, 2009 | 01:11 PM
unknown459's Avatar
Car: 1992 Z28 Vert
Engine: 5.0
Checked all the relays they work. fans still dont work. I tested them to the battery and they come on. Any other idea's ?
Old Jul 5, 2009 | 09:55 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Take a peice of wire, strip both ends off a little bit. Pull the two wires off for the temp sending unit that the electric fans attach to. Stick the wire onto the wire that run to the electric fans to complete the circuit. Do your fans turn on now? If not their is something wrong with the fans or a fuse. This method is bypassing all relays and sending units temporarily.
Old Jul 5, 2009 | 10:54 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
oups forget it.
eightsixseven
Dec 16, 2024 01:50 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
