Air dam question
Old Aug 9, 2010 | 04:59 PM
Big Cleatus's Avatar
Car: '84 Trans Am
Engine: 350 Carb
Axle/Gears: Stock but subject to change.
Air dam question
Where can I find an air dam? I've hit every salvage yard in a 100 mile radius, and checked every car part site I know of and can't find one. Mine isn't broke completely, but there is about a 4" chunk missing off of it.
Old Aug 9, 2010 | 05:11 PM
Car: '84 Trans Am
Engine: 350 Carb
Re: Air dam question
Also, another dumb question. I have the all plastic grille inserts, if I swap to those ones with the slots that kinda look like louvers, will those help cool my radiator? I saw those ones on Hawks third gen and on year one.
Old Aug 9, 2010 | 05:19 PM
Stephen's Avatar
Car: 87 GTA
Lots of people make their own from sheetmetal. I've never had to, so I'm not certain what they use, as far as thicknesses & such.
The opening in the nose offers noting for engine cooling. If you look under the nose, you'll see why.
Old Aug 9, 2010 | 05:36 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following site stocks a couple of different kinds:
http://www.moderndaymuscle.com/exterior4?b=1
JamesC
Old Aug 9, 2010 | 07:33 PM
Car: '84 Trans Am
Engine: 350 Carb
Thanks. I'll check that website out here in a minute.
It was kinda hard to look under the nose, I have the ground fx kit. I happened to look at a diagram of the front end in my year one catalog and I see what your talking about. The front impact absorber and the front reinforcement bar. Is that what you were talking about?
Old Aug 9, 2010 | 07:42 PM
Stephen's Avatar
Car: 87 GTA
Not really. On 'birds, 100% of the cooling air comes in from underneath. There is a big plastic "plate" that curves from bottom to top, to act as an "airfoil" To help the air flowing under the car move up through the radiator as well as getting caught by the air dam.
You have to get under the car & look up, behind the fascia, to see what I'm talking about.
Old Aug 9, 2010 | 08:18 PM
Car: '84 Trans Am
Engine: 350 Carb
I'm not seeing what you were talking about. The only plastic up there was the air dam and the ground fx. That curves upwards. Other than that it was empty space. I felt around and didn't feel anything.
Attached Thumbnails Air dam question-0809101904a.jpg   Air dam question-0809101904.jpg   Air dam question-0809101903.jpg
Old Aug 9, 2010 | 08:28 PM
Stephen's Avatar
Car: 87 GTA
Either it was added in later years (my 87 has one), or it is missing. Probably just added.
It attached to the lowest portion of the nose & curved upwards, attached to the top of the radiator. So any air that goes under the car, it "pulled up" by the airfoil effect, in addition to the air dam catching air & directing it up & through the radiator.
Old Aug 11, 2010 | 07:04 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
you could try GM i got one the other day for a 94 camaro it was 41 bucks not sure if they will still have one for our cars
Old Aug 11, 2010 | 08:22 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
do ALL thirdgens have these? the reason i ask is because i went to install mine on my new 86 and i cant find the holes for it.
Old Aug 11, 2010 | 08:26 PM
Stephen's Avatar
Car: 87 GTA
Yep. ALL Camaros & Firebirds got them. I've seen a couple of different designs & if you held one up there & the holes weren't there? Maybe you just had a different design?
Old Aug 11, 2010 | 09:50 PM
Engine: L31 350
idk, i know i have the other peices to the dam,ect the black parts that cover under the turn signals, but i just didnt noticed any holes.
Old Aug 12, 2010 | 07:39 AM
JamesC's Avatar
Camaros (at least some) have a Baffle, Rad Air Lwr GM p/n 14107379. Pic in the following link, post #1:
https://www.thirdgen.org/forums/body...ed-baffle.html
JamesC
Old Aug 19, 2010 | 02:47 PM
Mrs.Crasher0083's Avatar
Car: 88 Pontiac GTA and 4 Camaros
Engine: 5.7
From the looks of your pics....your missing the duct work that runs from the grill area to the radiator. Most likely its been taken out. We're actually experimenting with this on the track in our 92 RS. Id say that any grill that offers more air flow is better. The air dam is a must though. We use regular sheet metal and aluminum angle to fab a new air dam. Best of luck.
Old Aug 19, 2010 | 10:36 PM
Car: '84 Trans Am
Engine: 350 Carb
The whole front fascia is a replacement. Maybe the air duct stuff your talking about wasn't added back in. Maybe that's why my car runs at around 220-240 degrees. I dunno. I like the look of the all plastic grill inserts, but if the louvered ones will help with cooling I will definately swap them.
Old Aug 24, 2010 | 02:32 PM
Car: '84 Trans Am
Engine: 350 Carb
Anyone have pics of the internal duct work? I've never seen what it looks like other than the air dam. I guess I'll need to fab something up.
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
wruiz
Aug 13, 2015 09:07 PM
