fan relay wiring 91 z28
Old Oct 23, 2010 | 12:27 PM
pjp209's Avatar
Car: Gone
can anyone help rewire my 91 z28 tpi dual fans to original relay. currently running on a toggle switch, switch is hooked up to fuse box it melts after awhile thats why i need help rewiring it. no ac
Old Oct 25, 2010 | 11:38 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fan Plan
The PO probably jerry-rigged the deal because he didn’t know how to repair it.
You need to find out if the fan relay(s) is being energized.
The fan relay is on the left firewall.
It’s the one nearest the booster.
Make sure the FAN fuse in the fuse block is good.
Then you can make sure the fusible link is good.
Then using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) see if there is power on the orange wire at the relay.
You can test much of the circuit by having the key in the RUN position then grounding pin B of the ALDL
(Assembly Line Diagnostic Link).
When you ground it the fan relay should energize.
If it doesn’t you can repost for repair information.
If it does connect the fans
+ leads to the relay output.
If the relay doesn’t energize when the engine is hot you can test and replace the Coolant Temperature Sensor.
For the long run you might want to replace the relay with a high capacity one for longevity.
Happy Racing!
If You’re Passed By Your Own Tire On The Track, It’s Time For A Pit Stop
Old Oct 31, 2010 | 05:23 AM
pjp209's Avatar
Car: Gone
Re: fan relay wiring 91 z28
relay dont work
Old Oct 31, 2010 | 09:19 AM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
I would never run anything that draws that many amps directly through a switch. Wire it back up to stock and see if it works. Find a wiring diagram and make sure everything is correct at the relay, thats usually where most wiring mistakes are.
Old Jan 26, 2011 | 01:51 PM
pjp209's Avatar
Car: Gone
cant find any wiring diagram
Old Jan 26, 2011 | 02:08 PM
Car: 87 Camaro
Engine: 305 LG4 (H)
I'm a little busy at work at the moment but a little later I'll PM you a diagram, its a factory 350 TPI right?
Old Jan 26, 2011 | 02:20 PM
pjp209's Avatar
Car: Gone
yes it is. thanks
Old Jan 26, 2011 | 02:24 PM
bcnvz28's Avatar
Car: 16 Equinox,12 Silverado,91 Z28
Engine: 3.6l, 5.3l, 305 H.O.
Transmission: 6 Spd auto, 6 Spd Auto, 4 spd Auto
This should help.
File Type: pdf
Old Jan 26, 2011 | 02:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You could just run a seperate fan controller. Most auto parts stores sell them - anywhere from $35 - $100+. They are easy to wire, probe the radiator rather than the block so no messing with coolant in the face, and many brands available with many options. I run Flex-a-lite from Summit, best $100 I ever spent. Fully adjustable temp settings, options for manual on/off switches - really nice unit. Took 1 hour to install - no need for any of the factory stuff (relays, switches, etc), comes complete.
Old Jan 26, 2011 | 02:40 PM
pjp209's Avatar
Car: Gone
koo ima try to get at it asap
Old Jan 26, 2011 | 04:09 PM
Car: 87 Camaro
Engine: 305 LG4 (H)
Pm sent
Old Jul 29, 2020 | 06:52 PM
devilschariot's Avatar
Engine: 305 tpi
Shoutout to bcnvz28.
Thanks. Don't sift through endless debates between people who don't know what they're talking about. Just click his link. Done. There it is.
Old Jul 29, 2020 | 10:17 PM
jczoka's Avatar
Car: 1991 Z28 5spd
Just in case you need it, these are from my 91 GM service manual. This shows a little bit more detail, If it helps.
mmadden55
Feb 8, 2016 09:56 AM
Black Bird
Aug 27, 2012 06:52 PM
Stevolwevol
Aug 3, 2010 04:37 PM
Stevolwevol
Aug 2, 2010 05:16 PM
xxx3man`
Feb 25, 2010 02:20 PM
