Electric fan relay burned out
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I replaced the socket for the radiator fan relay, and it worked fine for a while. Then the relay burned out. I just replaced the relay this spring in May. Maybe it was because I was messing with it.. plugging it in and out etc. before I replaced the socket. Any input would be appreciated.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Relay Race
What part of the relay burned out?
The contacts or the coil?
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Happy Racing!
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Re: Relay Race
replace the relay , take the old one apart and see what happened whether its the contacts or coil that went
Re: Relay Race
I busted it open with a hammer. The coil as far as I can see looks good. No visiable signs of "burning". The contacts look like they are intact also. There is some discoloration in the white plastic. Kind of brownish where the red wire contact is.
Re: Relay Race
brownish spot could be your problem area,by the way you didnt need to use the hammer the white bottom slides out from the black cover
Re: Relay Race
There was no way to slide the white bottom would slide out of the cover. It was pressed in very snugly. Made in India. The old socket had melting where the red wire was connected. I'm gonna replace the fan motor. I checked the wiring, and it was good. No resistance. I have probably put stress on the motor by having it on constantly.
Transmission: 765R4
Relay Race
I have probably put stress on the (relay) by having it on constantly.
Anyway a reason for melting/failure is dirty socket contacts on the power wires of relays.
The dirt causes resistance which produces heat.
Happy Racing!
Why Did They Say I Was Speeding In The Pits? There’s No Speed Limit Sign.
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Relay Race
wondering if maybe your fan motor's on its way out? seen in some cases where a failing motor draws more amperage than what it was rated for and causing issues with relays/fuses. definitely shouldn't be killing relays that quickly (unless you were unfortunately stuck with a dud)
Re: Relay Race
I think I'm gonna replace the fan motor. The relay was in the old socket before I installed the new one. The old socket had heat issues. There was melting around the red wire tab. I don't know if the old socket was bad and caused the relay to burn out, or the fan motor is drawing too much do to it being bad.
gta892000
Sep 16, 2015 12:37 AM
