5.7 IROC overheats worse now with wetter water?
Car: 1988 IROC-Z
Engine: 5.7 TPI with zz4 heads
Axle/Gears: 9 bolt BW
Ok so here it goes I got this car with a blown head gasket replaced heads with zz4 heads and 190* thermostat. The car idle's at 160* and would go up to 220* in traffic and highway, the mech that did the swap put straight anti-freeze, so in order to help the temp down I flushed the radiator added wetter water and distilled water for a better mix. And now it shoots up to 230* and Im not even ragging on it! WTF.
So here are my thoughts Im on a budget so I cant go 3 row with dual fan's (cost for said set up is $550). I was thinking of doing an aluminum 1 row rad with a dual fan set up that blow's 4000 cfm ($350).
Notes: NO! the air dam is not in place just purchased one waiting for it to arrive
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
Re: 5.7 IROC overheats worse now with wetter water?
dump the system then fill 50/50 premix antifreeze then bleed the system i dont know why but this is forgotten. let it up to operating temp with the cap off
Car: 1988 IROC-Z
and then do what just put the cap back on?
Ok and if I do this you think its going to help my overheating issues...remember it used to overheat before I first flushed it.
Engine: gone
Transmission: gone
Axle/Gears: gone
boiling point of water is higher than antifreeze so you might actually see a little higher temps. are you sure the temperature gauge is working correctly?
Car: 1988 IROC-Z
It felt significantly warmer inside the car when it was creeping up to 230* I dont know if the temp is correct, how do I test it?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Car still have the air dam underneath? These cars do not overheat on the road AND stay cool at an idle unless the air dam is gone or damaged.
Car: 1988 IROC-Z
Car: 1988 IROC-Z
yeah but it still runs warmer even idling....oh well I went ahead and got a champion 2 core all aluminum radiator.
http://cgi.ebay.com/ebaymotors/Camar...ht_6902wt_1165
hey guy's since I got this radiator im thinking of up grading the electric fans....how much cfm should I look for in the fans in order for it to cool a mildly built up motor?
Engine: gone
Transmission: gone
Axle/Gears: gone
4th gen fans. no problemo
Car: 1988 IROC-Z
what you think about this
http://cgi.ebay.com/ebaymotors/ZIRGO...#ht_2635wt_939
only a 15 amp draw and 3000 cfm not bad at all
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
If it isnt boiling out of the overflow, it isnt overheating. My car without an air dam ran between 220-240 and one day hit 260 and really overheated, had to pull over and smoke was everywhere, etc... Now that I have an airdam 220 is as high as it will get, and that is perfectly acceptable for these cars. I know you said you ordered one, thats good. Once you install it you will notice a drop in temperature while driving. But, 220 is a normal temperature for a thirdgen to be at. If you get a cowl hood that temp will drop because the hot air will escape through the cowl. My camaro with a cowl hood ran at 190 all day long.
Car: 1988 IROC-Z
Thanks I was wondering if it was somewhat normal what had me a little freaked out is that I have aluminum heads. I would like for the temp to stay under 200 at all times if possible.
Car: 1986 chevy camaro z28 coupe
Engine: crate 355
Transmission: 700r
Is it normal for the temp to go up and down constantly? For instance cruising at 55mph temp 200 then get into town at 25mph and it drops to 160-170. My other car stays the same temp all of the time.
Not trying to hijack PAB'S just thought you had it figured out.
Car: 1988 IROC-Z
well I think the 3000 cfm and 2 core aluminum rad will help some....oh yeah and the air dam lol
ok hold on here. ANTIFREEZE HAS A HIGHER BOILING POINT THAN WATER. now if it is all antifreeze it will run hotter. WATER IS THE BEST COOLANT. what you need to do is drain everything. add one gallon antifreeze, then the rest water with one water wetter bottle in. then go from there.make sure the airdam is in. get a newer thermostat. make sure all the air is out of the cooling system. when filling the cooling system back up from being drained i leave the upper radiator hose off till i fill it that high. then put it on and continue filling.
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
The boiling point of ethylene glycol : ~388 F
What is ideal in the car is a solution that enables us to take advantage of the increased boiling point because of the pressurized nature of the system.
When I install thermostats now, I drill small bleed holes to help bleed some air out of the system.
Stick a thermometer right into the neck of the radiator to see the actual temperatures, those gauges and the temperature sender are inaccurate. I replaced the temperature sender like 6 times until I found a good one (an AC Delco).
Car: 87 Camaro
Engine: 305 LG4 (H)
That is totally not true, mine gets hot (220 or so) as I'm driving and dips back down to 190 or so when I'm idling. With the air dam completely intact. Granted this is not normal and there is an underlying issue, I though I'd chime in so the OP doesn't go around chasing an issue that isn't causing his concern.
OP I'd make sure the system is clean and flowing with no air pockets, then check the actual coolant temp and see if the sensor is just reading inaccurate. My advice though - don't add ANY aftermarket parts until the system is working as designed or its going to be that much harder to diagnose.
I had problem with running hot with the A/C on during in town driving. I kept lossing coolant until I found a leak in the lower radiator. Short story, after the radiator was pulled I found the real problem: Complete blockage of the cooling fins behind the A/C condensor (about 40% of the cooling fins)
. No wonder I had a cooling problem in stop & go traffic.
This area is completely hidden unless you remove a lot parts. Replaced the Radiator and now with the A/C on or off in town 180 deg Max and lower on the highway. My problem solved.
So check that hidden area.
. No wonder I had a cooling problem in stop & go traffic.This area is completely hidden unless you remove a lot parts. Replaced the Radiator and now with the A/C on or off in town 180 deg Max and lower on the highway. My problem solved.
Engine: gone
Transmission: gone
Axle/Gears: gone
The boiling point of water: 212 F
I meant that backwards sorry. thanks for correcting me. water boils before antifreeze. I know that. my bad! Supreme Member
Car: 87' IROC
Car: 1988 Camaro sports coupe
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
I love Water Wetter! That said, you need that air dam. GM wouldn't put that ugly thing on there if it wasn't necessary. Once you get that on there you should be good to go.
Another thing to consider is air pockets. Get the motor up to operating temperature, drive the car on a steep incline and decline with the heater selector set to hot. Make sure you have hot air blowing out of the vents to confirm water is flowing. This will help coax those air pockets to work themselves loose. Sometimes you just need to drive it for a while to get them out. My 97 Blazer took months to get them out of the heater core.
Car: 1988 IROC-Z
87350IROC: I dont agree that spending money on a good radiator and fan is a waste. If it dint happen now it would have been done anyhow. Texas is also way hotter than WA I bet you guy's flip out if you hit 90*, so do we but because its normally closer to 100*
Dippin: No thanks I dont need another motor hehe
Krick: Im fully aware I need the air dam but it got hotter with wetter water WTF? lol
Car: 87' IROC
Regardless I guarantee you beating the **** out of a car for 30mins on a track in 90 degree weather is way harder on the cooling system than driving home from work in 110.
A high performance radiator is not a waste of money. But it will not solve your problem.
Car: 1988 IROC-Z
I agree it wont solve the problem by itself but that's why Im doing all 3
1. Air dam
2. Radiator
3. High cfm fan
plus Im also going to check into the pump, stat and whatever else I can think of.
1. Air dam
2. Radiator
3. High cfm fan
Car: 87' IROC
Sounds like a plan. Be sure to check out Spal for fans and Stewart for water pumps.
Car: 1988 IROC-Z
Are water pumps like fuel pumps? Can I get one that flows more?
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
use a 160 stat and hypertech 160 switch and that will lower the temp mine never sees over 200 with the AC
Engine: 5.7 TPI
Not my 1st hand knowledge, but what I have read on these forums.
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
You are both wrong. No reprogramming of the ECM is not required and your car will still go into closed-loop operation, even with the 160* thermostat. It's the fan switch that controls when the fans turn on and if you get the correct one for your thermostat temp you will be fine. Just make sure you fans come on after the thermostat is open. I use a 170* thermostat and my fan kicks on at 195* and have never seen water temps over 205* here in the AZ summer with a stock cooling set-up and 425HP.
Engine: 5.7 TPI
I will concede that there are two schools of thought on the subject. I announced that I was no expert on the subject and was just reposting what I had read.
Car: 87 Camaro
Engine: 305 LG4 (H)
This should be posted in large letters at the top of all forum pages - except it should pertain to ALL parts on the car. The general doesn't spend money unless he has to, and I keep reading of people removing components basically because they are "there" and think they are useless or to "clean up" the engine bay (whatever the hell that means).
Engine: 5.7 TPI
Another example is the baffles under the air filters. They make the car a bit louder, but that isn't a problem for me, especially at the gain of a slight hp upgrade.
I have kept all the original parts, and I could restore it back to stock in a couple of hours if I needed to.
tl;dr
Make your car your own, but know the consequences for your actions in advance.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If it's not boiling over it's not overheating.
The boiling points of water and anti-freeze are not indicators of their thermal properties. The SPECIFIC HEAT of a water/anti-freeze solution is actually LOWER than a pure water solution. We add anti-freeze for two primary reasons: 1) freeze protection (a 50/50 solution won't freeze until near -30 F and 2) corrosion protection (anti-freeze raises the pH of the solution and prevents rust).
Water wetter does not improve the thermal properties of the solution either. It does, however, help prevent cavitation which is the formation of small pockets of water vapor in the system. Cavitation is bad because these pockets prevent the coolant from having direct contact with the pieces it needs to cool.
A high flow pump can cause cavitation, which is bad (see above). A high flow pump may push water through the system faster than it can be fed from the bottom rad hose. Water wetter probably doesn't have enough miracle powers to prevent this type of cavitation.
What are your real temperatures? I mean the actually 'measured' temp? Do not be confused into thinking that the pointy, wavy thing on your dash is any indication of the actual state of nature at the end of the sensor.
How is your tune? A well tuned motor runs cooler because it's running EFFICIENTLY. It will produce the least heat for a given power requirement.
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Also, I'm assuming you're aware that you significantly raised your compression ratio by swapping to those heads? The stock heads have 64cc chambers and the heads you just put on have 58cc chambers. This raises your compression ratio to about 10.3:1. Your cooling system should still be able to cool it, but be careful with the ignition timing. You have aluminum heads but you also raised the compression. To get the most out of your combo you should have it tuned.
Again, not saying the compression is causing your cooling problem, but want to make you aware that you have significantly raised your compression.
Car: 1988 IROC-Z
Well Im back in the states!!! I got my air dam on ASAP and that did it, now my car temp wont go above 160*
Reference:
https://www.thirdgen.org/forums/tech...-persists.html
Also, the primary fan should be ECM controlled.
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Car: 1988 IROC-Z
I have a 190* stat I dont know why it wont go above 160*
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
This means either you have a fualty thermostat, or your guage is inaccurate. I would go with the later. When I put all Auto Meter guages in my car, my temp instantly read 20 or so degress hotter. I trust the new Auto Meter guage more than 20 year old factory guages. Especially since now as soon as my guage hits 180, I can watch it go back down a little, then back up. I'm running a 180 thermostat. I would get an infared thermometer and measure the radiator to see what it actually is. And I agree that 160 is too cold. If you have a 190 thermo and thats what its actually running at, then that is good.
Car: 1988 IROC-Z
i figured that Ill go ahead and get an accurate reading
ambainb
Apr 25, 2016 09:21 PM
mustangman65_79
Aug 11, 2015 03:17 PM
lol
