Should I go ahead and replace accumulator and orifice tube?
Old Jul 13, 2011 | 09:14 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I am finally getting close to getting the A/C system straightened out on my 88 camaro. After the original owner gutted the A/C system in my car, I installed a unit from a wrecked 90 RS camaro that I had. From what I can tell the system has never been opened and it does not leak.
Currently the A/C doesnt work as it should and I plan on having the existing r-12 reclaimed, pull a vac, and recharge with R12. I spoke with a local mechanic and he recommended going ahead and replacing the accumulator and orifice tube since they were cheap.
What do yall think? I will already have it evacuated so it wouldnt be hard for me to change out. I just dont want to possibly cause a future leak.
Old Jul 13, 2011 | 09:52 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Should I go ahead and replace accumulator and orifice tube?
i'd agree with the mechanic. there's a slight chance stuff could have gotten into them and its just cheap and easy insurance. rather spend a couple bucks now than regret the big bill later!
Old Jul 13, 2011 | 10:09 AM
3rdgenmaro's Avatar
Car: 88 IROC
Thats what I was thinking. I can get AcDelco from Rockauto. $20 for accumulator $2 for orifice tube.
Rockauto lists 2 accumulators from AcDelco. One shows #151605 the other #151883 I wonder what the difference is.
Is there anything else I should go ahead and get or replace?
Old Jul 14, 2011 | 10:31 AM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
He he right. You should also replace all the Orings. Better to do it rigth once, than having to do it twice.
Old Jul 14, 2011 | 11:35 AM
3rdgenmaro's Avatar
Car: 88 IROC
What about the inline filter? Should that be replaced? Im just going off parts Rockauto sells.
Old Jul 14, 2011 | 11:37 AM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
If there is one yes.......replace it. My 84 system did not have seperate inline filter.
Old Jul 14, 2011 | 06:45 PM
3rdgenmaro's Avatar
Car: 88 IROC
yeah I dont see one on mine either.
Old Jul 18, 2011 | 04:47 PM
Mitch91Z28's Avatar
Car: 1991 Vert Z28
Engine: 305... LS1 waiting to drop in
Transmission: 700-R4... soon 4L60E
Axle/Gears: 3.08 posi nine bolt
when i replaced mine there was two options as well, one of the accumulators had a r134a fitting on it, the other was a r12 might want to call them and make sure
Old Jul 19, 2011 | 04:44 PM
3rdgenmaro's Avatar
Car: 88 IROC
thanks for the info.
I went ahead and ordered the one listed as OEM. I will post up which ends it has. I already have the conversion R12 to R134a ports if I need them. Im still running R12, but the 134a ports are much easier to work on. (im not selling the car so I dont ever have to worry about future owners so I dont really care. I will remember)
TheExaminer
Aug 26, 2015 04:59 PM
theshackle
Aug 22, 2015 06:52 PM
justin57
Aug 20, 2015 07:05 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
