A/C/Heater not working correctly
Old Sep 22, 2012 | 09:46 PM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
I just put a new fan motor control switch in, it does adjust it from low to high, but it does not blow hard. When I first put the switch in, it did blow hard. Also I can not get the air to blow out of the dash vents, just the defroster vents, and its always on, even if the switch is off. Any suggestions on what both could be?
Old Sep 23, 2012 | 06:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: A/C/Heater not working correctly
Defrost is the default setting and indicates that there's a vac leak somewhere. Stick your ear to the pass side of the HVAC and you may hear a hiss. If so, the following info will be helpful:
https://www.thirdgen.org/forums/inte...anent-fix.html
JamesC
Old Sep 24, 2012 | 08:51 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Ok I checked for that, I did not hear anything with the car on or off. I also noticed that when I turned the A/C or heat on, when I shut the car off it stayed on, to turn it off I had to just turn the switch to low
Old Sep 25, 2012 | 09:14 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
OK I did the fix in the thread you showed me, helped sort of, the blower motor is fine now, now I gotta hunt down an A/C selector switch, can anybody give me a lead to a new one? I can not find one in stock
Old Sep 25, 2012 | 09:34 AM
JamesC's Avatar
Valve Vac Sel GM part # 16032395.
JamesC
Old Sep 25, 2012 | 07:40 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
found it! Thanks!!! got it ordered!
Old Sep 25, 2012 | 08:30 PM
VanWailin's Avatar
Car: 1992 Chevrolet Camaro RS
Just curious. Where did you order it from?
Old Sep 26, 2012 | 10:17 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
http://www.rmsautoparts.com/ only place that has it in stock. Here is the exact page: http://www.rmsautoparts.com/proddeta...?prod=15-71408
Ghettobird52
Jul 5, 2024 11:18 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
Vintageracer
Aug 11, 2015 08:13 PM
