removing ac compressor?
Old Jun 14, 2015 | 07:13 PM
sleprock's Avatar
Car: 1986 irocz
Engine: 383 with ds1 procharger
Axle/Gears: moser 9' 370's
i just got the ac delete box for the firewall. the smog pump is allready gone now iam removing the compressor. what do i do about the big ugly bracket that hold the smog pump and compressor? the tensioner pulley is there allso.my car is a 86 with a 88 and up serpentine belt setup due to the procharger.do i buy a ac delete pulley or what? i want the big bracket gone.iam lost on this. is there a write up on this or can someone point me in the right direction.
Old Jun 14, 2015 | 07:41 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: removing ac compressor?
Do you have the serp belt system on your car?
Old Jun 14, 2015 | 07:50 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Assuming you do. You'll need to retain the bracket so the tensioner has a mount. You can get an a/c delete pully. I'm using this one that I found on Amazon.com for about $30.00
Dorman HELP AC Bypass Pulley 34157
I'm also running an idler pulley where the smog pump used to be just so that long space between the a/c delete pulley and the crank is accounted for.
I looks like this when it's all back together.
This is all assuming that you have the same belt system as I do on my 91 model car.
Old Jun 15, 2015 | 11:57 AM
sleprock's Avatar
Car: 1986 irocz
my car does have the serp, belt setup. where can i get the bracket for the tensioner? and what idler did you use? part no# thanks for the help.
Old Jun 15, 2015 | 12:22 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
The stock A/C and smog bracket is the mount for the belt tensioner. Does your bracket look like this? Or are you saying you no longer have or never had the the bracket?
I think I got my pulley from jegs or summit. Can't remember. I think this is the p/n though: Chevrolet Performance 10129569
Old Jun 16, 2015 | 11:31 AM
sleprock's Avatar
Car: 1986 irocz
ya thats the bracket i have on my car. but i was looking for somthing differant.do they make or did they make a differant bracket?
Old Jun 16, 2015 | 04:50 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
I'm not sure such a thing exists..unless you want to go to a completely new/custom style serpentine belt system for the whole engine. That setup above with the stock brackets and delete pulleys is typical of what you'd see on a lot stock-ish thirdgen cars though.
Old Jun 19, 2015 | 12:33 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
No real good solution. Most likely you'll need to convert to v-belts or go to an aftermarket serpentine setup to get rid of that bracket.
Old Jun 19, 2015 | 02:32 PM
sleprock's Avatar
Car: 1986 irocz
iam wondering how sturdy the bracket would be if i cut the bottom off about where the smog pump was?
Old Jun 19, 2015 | 05:48 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Not sturdy at all since it's all one unit.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Stroopwafel
Sep 11, 2015 06:38 AM
