Coolant Tank Retaining Clips
Old Dec 16, 2016 | 02:20 AM
That Sky Guy's Avatar
How's it going y'all? I hope this isn't a silly question, but I have come seeking knowledge.
I recently installed a new radiator overflow tank... issue is, the retaining clip broke just before removal. I took it to Autozone to get a 'replacement', and the one they gave me looks just like it, yet doesn't work at all.
I managed to find this:http://http://www.classicindustries.com/product/camaro/parts/20451119.html
Is this the correct part for my '89 Camaro?
Thanks in advance guys!
Old Dec 16, 2016 | 06:52 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Coolant Tank Retaining Clips
There are a few threads with this info if you are wanting them to be "correct".
The search function is kinda hit or miss here so you may have to work at it a bit.
Old Dec 16, 2016 | 12:14 PM
Drew's Avatar
If you have a local body supply store, just take the old one in and have them match it up. Or flip through Auveco's catalog and see if you can match it that way.
The current number GM gives comes as a square push pin, which might work, but isn't close to the original style.
In the off chance you have a junkyard with a fair selection, it's not too hard to find at least one of these clips with 4 per car.
Old Dec 16, 2016 | 02:25 PM
gt4373's Avatar
Transmission: 5-Speed Manual
According To The Website It Only Fits 1982-1988.
Old Dec 16, 2016 | 04:41 PM
TTOP350's Avatar
Those work all the way to 92.
Old Dec 16, 2016 | 06:08 PM
So those above clips are good for my '89?
I mean, they look similar... I just don't want to waste the time and money, you know?
Old Dec 16, 2016 | 06:12 PM
Quite right, the only reason I posted a separate thread was because I simply could not find any decent info using search.
Old Dec 16, 2016 | 06:25 PM
TTOP350's Avatar
Sometimes google will bring it up better..
https://www.thirdgen.org/forums/hist...-radiator.html
Old Dec 16, 2016 | 08:31 PM
Ah I see, I think I found a promising lead, thanks to yourself, kind sir.
Link:
http://www.clipsandfasteners.com/GM_...r_p/a13457.htm
This looks like it, do you think it's the correct one?
The thread kinda goes back and forth a bit, and the other clip provided was said not to fit right.
