1988 Chevy camaro 2.8l boiling coolant.
A little back round. I own a 1988 Chevy Camaro with a 2.8L engine. I took it out of storage as i live in Minnesota and the vehicle is usable about half the year. I noticed after idling for approximately 15-20 minutes the coolant starts to boil. It has blown my coolant reservoir cap off once already and i am stuck. one thing i have noticed is that the fans do not turn on anymore. Any help would be appreciated.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 1988 Chevy camaro 2.8l boiling coolant.
I would start by checking your coolant level and finding out why your fans dont work
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Maybe check the radiator cap, if its not sealing, water boils into the expansion tank.Possibly, well before the fan comes on.
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
my car did the same thing, my fans now come on when I turn the key and she stays a nice 120-150 in dead stopped traffic get back to to us with what u find, if you need to troubleshoot the fans it's real easy and I'd be happy to tell u how
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Trace your fan wiring.
Find the fault and fix it.
Boiling Coolant typically indicates a leak, or your getting HELLA hot in your engine.....
Your cooling system is WAAAYYY simpler that lots of people here make them out to be.
Do what W.E.G said!
Do what W.E.G said!
Car: 93 Trans Am
Transmission: T56 Street Twin
Axle/Gears: 12 Bolt 3.90
Mine would did similar, it actually over heated after about 45 minutes in stop and go traffic over the summer, dual fan car, only one was running, passenger. Bad relay, replaced both as a pair as they were both original. Rebled the cooling system and it was fine after that.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
1Aauto
Sponsored Vendors
Jan 12, 2017 01:47 PM
1Aauto
Sponsored Vendors
Sep 19, 2016 08:11 AM
Dan87IROC-Z
Aftermarket Product Review
Dec 10, 2000 04:26 PM
