Rust chunks in my cooling system
Old Jan 29, 2018 | 06:21 PM
MoMoney's Avatar
The previous owner of my car basically let it sit for awhile and didn’t really do much to it, I noticed I had all this brown gunk in my radiator and flushed it with at the mechanic with water and coolant but I don’t know think he flushed it thoroughly, should I flush the entire system and block or should i just replace the radiator?
Old Jan 29, 2018 | 06:23 PM
Drew's Avatar
Re: Rust chunks in my cooling system
Well, the radiator is aluminum and plastic, where do you suppose the rust originated from?
Old Jan 29, 2018 | 06:29 PM
MoMoney's Avatar
No idea... I’ve had the car almost 3 months and I’ve put a lot into it so far, this was the first issue I noticed when the mechanic popped off the cap and it threw up
Old Jan 29, 2018 | 06:32 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Engine block rust, bars leak residue ! Or glycol mixed with dexcool
Old Jan 29, 2018 | 06:47 PM
MoMoney's Avatar
So do you think I should flush the entire block and the cooling system?
Old Jan 29, 2018 | 06:49 PM
Engine: Lb9
Transmission: M20
Yes , I would flush it and replace the thermostat.
If it starts to overheat replace the radiator.
Old Jan 29, 2018 | 06:56 PM
Drew's Avatar
What I was getting at is that aluminum and plastic don't rust. Rubber hoses don't rust. So what does? Cast iron? Like the engine block? Yep, cast iron will rust. So you need to pull the water jacket plugs out of the block, flush all the garbage out, and go from there. Otherwise the garbage in the block is just going to mix with your new fresh anti-freeze and contaminate it.
Old Jan 29, 2018 | 10:08 PM
NoEmissions84TA's Avatar
Do multiple flushes until (IF) it cleans up. An old radiator shop owner told me to use 1 cup of Lestoil to clean, and baking soda to neutralize acids (not at the same time). Try to remove the 1/4" plugs on each side of the block (center) just above the oil pan rail. Short of removing the "freeze" plugs (good luck with that), those 2 plugs are the only way you can get the chunks out of the lowest areas of the block. Just keep doing the Lestoil flushes with tap water. Run the car for a while so it can clean. Drain and repeat until you are satisfied. Then when you are ready to use coolant again, use DISTILLED water.
Because it is winter, when filling the cooling system with water only, you risk freezing and cracking the block if the temperature gets too low.
A friend of mine lost an engine this way.
Old Jan 29, 2018 | 10:17 PM
1 Quick T/A's Avatar
Car: 92 Firebird
Axle/Gears: 3:42
I've had great success with this product from Napa auto parts...
Old Jan 30, 2018 | 04:34 AM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
Here is what I did to my 3.1 V6: I drained the radiator and cooling system and refilled it with a 50/50 mixture of distilled water and white vinegar. I then ran it for a day or two(keeping it in the normal temperature range) and then took it to my mechanic for a full radiator flush- they were NOT happy!! You should have seen all the foaming brown mess that drained out! But it sure cleaned out the system! It looked like I had been running my cooling system with a rootbeer float...
Old Jan 30, 2018 | 08:24 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I have had good luck combining these two things. Replace any hose you cut when you are done.
Amazon Amazon
Amazon Amazon
pmacd
Mar 3, 2012 05:56 PM
Dead Reckon
Feb 9, 2012 10:18 PM
stiffert/a
Mar 3, 2003 09:32 PM
Raptor Pilot
May 18, 2002 02:22 PM
Spindr130
Jul 18, 2001 11:39 PM
