perplexed
Old Aug 29, 2018 | 09:22 PM
dmm3369's Avatar
Car: 83 Z28 / 89 IROC
Engine: 350's
Transmission: T5 WC / 700R4
Axle/Gears: Posi 3.73
perplexed
I have a 89 IROC. New GM engine 350 HO version, New everything on the engine, New Radiator, New hoses, new thermostat swapped 3 times. . Both my fans are new 12 inch electric fans. One comes on at 165 and the other is controlled by the computer. The air dam is in place.
My temp are hitting 230 and 240. I even checked it with my PC connected and the temp matched my digital temp gauge. I have read through a lot of the cooling threads this just makes no sense.
Im tired of messing with it geez. What does it take to cool these cars??
David
Old Aug 29, 2018 | 09:37 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: perplexed
Is the air dam new? Are the fans turning the correct way? What kind of replacement fans did you install? Did you get the correct direction water pump?
Old Aug 29, 2018 | 10:14 PM
dmm3369's Avatar
Engine: 350's
Re: perplexed
Its the stock air dam iroc style. Fans are turning correct. They are electric 12 inch fans. Water pump is reverse flow brand new.
Old Aug 29, 2018 | 11:18 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: perplexed
Are the fans right up against the radiator? What brand of fans?
Old Aug 29, 2018 | 11:39 PM
Go Blue's Avatar
Re: perplexed
What Teal and Karr are getting at with the fan questions is that they want to make sure that you don't have 2 pusher fans acting like puller fans as that doesn't work! As for the air dam, they just want to make sure that it isn't cracked or not fully in place. I know you said that you have a new radiator, but when you replaced that did you check the fins for the AC condensor and make sure that they aren't clogged with road dirt and all of the dirt that was caked between it and the old radiator was fully removed?? If there's crap in the condensor fins then air isn't even getting to the radiator to help cool it. I have seen that a lot of times.
Old Aug 30, 2018 | 12:07 AM
1989karr's Avatar
Engine: 3.4 / 5.0
Re: perplexed
What Go Blue said!
Also, how about the often overlooked less likely things...belt routed correctly, exhaust free flowing, timing set etc..
These cars have basic cooling systems so I like to rule out the possible random oddball issue that more than likely won't but MAY cause the issue!
I had a similar issue once...the car couldn't;t get rid of an air bubble for the longest time for some reason. Of course I didn;t figure it out til leventually it burped and all was fine.....almost 3 days later lol
Old Aug 30, 2018 | 12:26 AM
dmm3369's Avatar
Engine: 350's
Re: perplexed
Fans are Upgr8 Universal High Performance 12V Slim Electric Cooling Radiator Fan Maximum Fan CFM=1750 CFM, Maximum Fan RPM=2250 RPM
Yes they are mounted to the radiator right up against it.
David
Old Aug 30, 2018 | 12:29 AM
dmm3369's Avatar
Engine: 350's
Re: perplexed
The condenser was cleaned during engine swap. What about the water bypass valve? could that do anything odd? Its new.
Old Aug 30, 2018 | 12:34 AM
dmm3369's Avatar
Engine: 350's
Re: perplexed
The engine I removed was also running to hot. I changed it all. The only thing left was the heater core which is new and the bypass valve. The ECM reading shows it really is that hot. This is the new radiator..
Amazon Amazon
Old Aug 30, 2018 | 06:42 AM
Re: perplexed
What individual cooling system components did you keep and carry over from the old motor to the new one? (wp, hoses, radiator, thermostat, ???)
Old Aug 30, 2018 | 06:56 AM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Re: perplexed
Do keep in mind that just because the fans are moving, doesn't mean they're moving fast enough...I've seen several times where the fan motor was tired, and simply moving too slow--but since it was moving, someone eliminated it as a possible issue.
Old Aug 30, 2018 | 07:09 AM
dmm3369's Avatar
Engine: 350's
Re: perplexed
None. The only thing I didn't change is the bypass valve on the heater core lines. I changed it all to make sure it didn't and it does .....
Old Aug 30, 2018 | 07:14 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: perplexed
Following..
Old Aug 30, 2018 | 07:15 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: perplexed
David
I would use a factory twin fan setup. Never had good luck with most aftermarket stuff. Not sure if its a fan blade angle issue or what.
Old Aug 30, 2018 | 10:46 AM
Go Blue's Avatar
Re: perplexed
The bypass valve could be clogged or starting to clog but it's not likely to do too much to be honest as the coolant should still flow through it and even if it's stuck open or closed, the coolant would still flow unless the it's clogged. If you take the radiator cap off, does the coolant move pretty well? Do you have any way to measure the different spots for different temperatures like an infrared temperature gun. Just wondering if maybe a cylinder is running too rich or too lean or there is a clog in the cooling system or anything like that??
Old Aug 30, 2018 | 11:03 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: perplexed
I would also do a pressure test. Maybe you have a small air leak in changing all this stuff and it is not pressurizing the system properly.
Old Aug 30, 2018 | 12:26 PM
BizJetTech's Avatar
Re: perplexed
Vinny R is correct - if the system is not developing the correct pressure, this will have an impact on your running temperature.
What pressure radiator cap are you using? Have you performed a system pressure leak down check?
Old Aug 30, 2018 | 12:40 PM
dmm3369's Avatar
Engine: 350's
Re: perplexed
Its a new 16lb cap. I have tried 2. I have not done a leak down but its all new but new stuff brakes and can leak.
Old Aug 30, 2018 | 01:07 PM
BizJetTech's Avatar
Re: perplexed
As a process in the troubleshooting my recommendation would be to pressurize the system and do a leak down check.
Additionally, you may want to insure you have all the air bled from the system. As a few others here have made reference to,
air in the system can cause problems.
Old Aug 30, 2018 | 04:13 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Re: perplexed
What T-Top said.
I personally think that fans that are directly on the rad and are not an X- amount of distance away don't do well since they only pull air where they touch the rad and don't have a shroud.
1. Does it get hot instantly when you idle? Stock the fans probably don't come on for I think 10 - 20 minutes at least, so if it gets hot too fast, its possibly not fan related...but if it overheats after the stock fans WOULD come on stock, maybe its fan related as they can't cool enough.
2. Does the ac get cold if you have ac? If not that might indicate air flow / fan issue.
3. Did you make sure it is the correct water pump for serpentine system? I once got the wrong part that otherwise looks stock and took me forever to realize the wrong part was in the box...because its identical to another part.
4. Would you consider wiring in LS / LT fans? You seem to have good skills so I imagine this wouldn't;t be a problem for you.
Old Aug 30, 2018 | 06:55 PM
Jp's camaro's Avatar
Car: 1991 rs, 1985 z28
Engine: 3.1 v6, 305 tpi
Transmission: 700r4, 700r4
Axle/Gears: 3.23, 3.23
Re: perplexed
I replied to your post on facebook but I'll post on here to.
Whats it idling at ? I had a bad tps which was causing a high idle and not allowing it to idle down enough while driving it caused it to run at like 220 or a little pass with my fan running
Old Aug 30, 2018 | 07:17 PM
dmm3369's Avatar
Engine: 350's
Re: perplexed
I want to thank everyone its finally cool again. I know this was mentioned. My 83 had a brand new air damn I installed from Hawks motorsport. I thought the IROC was cooled from the holes in the front at the fog lights and that the air damn was the radius plastic piece under the car running from the front bumper. After I reset the timing and put in a new 160 thermostat and set the fans to come on at 180 is did some better but finally went back up to 248. I verified everything again from flow direction to you name it. So I looked again online and saw the air damn was for 82-92 so I made a temp metal one and put it on and damn it went down to 205. I replaced everything under the hood over a damn piece of plastic. So once I get the new one I bet it runs even cooler since mine is shorter than the radiator.
Old Aug 30, 2018 | 07:47 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Re: perplexed
It's amazing how a piece of flat plastic can affect these cars so much!
Old Aug 30, 2018 | 08:25 PM
dmm3369's Avatar
Engine: 350's
Re: perplexed
Its amazing how it affected my wallet!!
Old Aug 30, 2018 | 09:10 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Re: perplexed
tell me about it...I just bought one recently myself.
I'm not convinced that base birds / Formulas need it though, but I was too nervous to take a chance haha
Old Aug 31, 2018 | 06:38 AM
TTOP350's Avatar
Re: perplexed
They will overheat on highway without it. ;-)
Old Aug 31, 2018 | 07:13 AM
Go Blue's Avatar
Re: perplexed
Be glad that you found it and that things are working again. Look at it this way also, all of the parts that you replaced were mainly maintenance items and will help the car to continue to run well and cooler in the future.
Old Aug 31, 2019 | 04:53 AM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
Re: perplexed
yes,they absolutely need the air dam especially in the firebirds.you know,no through path for air...
Old Sep 8, 2019 | 06:49 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: perplexed
thats the only way for air to be drawn into your radiator area is from under neath . the fog lights area isnt big enough for cooling alone. glad you found your problem
RiggsLW81
Apr 1, 2012 12:53 AM
327sleeper88
Sep 13, 2011 09:05 PM
Ward
Sep 13, 2009 01:01 AM
toogood002
Oct 5, 2006 03:12 PM
Abanda
Jun 14, 2006 11:09 AM
