loose my ventilation and heater
Old Nov 8, 2019 | 08:31 AM
Bavooz Flo's Avatar
Car: FIREBIRD TRANS AM GTA 1987
Engine: 5.7
Transmission: th700
Hi, I am french, I live in LYON, I have an Trans Am GTA 87 since 1 month, but after the flush of cooling, I has loose the heater and the motor of ventilation works but really less, no ventilation, in position cold or heat, same thing.......just a little bit....why ?
Before ventilation has work good, the heater ...I don't remember.....
If you can help me... Thanks
Old Nov 8, 2019 | 06:32 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: loose my ventilation and heater
vacume line for heater controls might have came disconnected during the coolant flush
Old Nov 9, 2019 | 02:29 AM
Bavooz Flo's Avatar
Engine: 5.7
Transmission: th700
Perhaps... I have this version of my car but where is vacuum line for heater controls ?
Old Nov 10, 2019 | 02:23 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Oh-you have electronic controls-I don't know too much about those,except I think vacume still operates the dampers-electric valves operated by control head switching the vacume ...Nice radio BTW Hopefully someone who knows firebird electronic controls will seethis and chime in...
Old Dec 1, 2019 | 09:41 AM
Bavooz Flo's Avatar
Engine: 5.7
Transmission: th700
Up, nobody knows firebird electronic controls ?
Old Dec 1, 2019 | 01:31 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
look around underhood for a disconnected vacume line since the trouble started with the coolant flush and also if no heat,might have "air lock"situation in heater core coolant path after the coolant flush-perhaps someone here knows how to bleed a late model thirdgen heater that uses the shutoff valve.
Old Dec 1, 2019 | 01:56 PM
Bavooz Flo's Avatar
Engine: 5.7
Transmission: th700
thanks for this feedback
Belle Fourche it is french that ahahah
I live in France
Old Dec 26, 2019 | 04:25 AM
Bavooz Flo's Avatar
Engine: 5.7
Transmission: th700
Hello,
My heater don't give heat... The ventilation is Ok, I removed the cover under the dashboard and when I active the buttom cold/heat, we hear a noise on the motor on the right(on picture) but without the rod or arm moving ? how the rod move ? with this motor and open the door for an access to the heat ?
The motor make some noise but nothing to move, possible to find one ? I don't find on rockauto, someone know this piece ?
Old Jan 4, 2020 | 09:10 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
The vaccum line, if yours still uses one, comes off the back of the engine and goes into the fire wall. Should be a hard plastic line.
Darkshot
Feb 15, 2008 09:48 PM
SeanTimothy
Dec 24, 2003 03:39 PM
Nasty_Bird_'90
Oct 27, 2002 08:33 PM
Brett
Apr 4, 2002 06:52 PM
