Help with fans
Old Jun 11, 2020 | 04:27 PM
Offalmangler's Avatar
Help with fans
Aquired an 88 GTA. Has stock duel fan seretup. Ac car. But missing ac peices.
Passanger fan is currently grounded out so it will run.
installed a new switch, and 1wire connector. Where does the wiring from the switch go to? They ripped out the old wiring for it. I know of 2 relays by brake booster. Neither of these has the "green wire with white stripe" the 2 relays by pass front engine compartment does however. One of these relays is where i have grounded the fan temporary. No other wiring from battey to switch etc.
and yes... i DO know where the 1 wire switch plugs into
Old Jun 11, 2020 | 06:45 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: Help with fans
Which engine do you have?
Old Jun 11, 2020 | 07:41 PM
Re: Help with fans
5.7 tpi
Old Jun 11, 2020 | 08:27 PM
jharrison5's Avatar
Car: '87 IROC
Re: Help with fans
This is out of my wiring diagram book for my '87 Camaro and might be of some help.
Old Jun 11, 2020 | 09:40 PM
Re: Help with fans
Kinda.. not the best at following wiring diagrams.
Old Jun 11, 2020 | 10:09 PM
Re: Help with fans
So what relays should i be looking at. By the booster or front pass fender. As by the booster there is NO green wire with white stripe. Only at front pass fender..
I am debating on removing all wiring from the sensors and installing 2 40 amp relays with the switch and having it a standalone system. That is my second option. 3rd is just going aftermarket.
Old Jun 12, 2020 | 07:59 AM
jharrison5's Avatar
Car: '87 IROC
Re: Help with fans
The fans are ran by the computer, so if you're not running the factory ECU I'd just go aftermarket. The system in my '88 GTA was trash when I bought it and I just started over with an aftermarket switch and relay system, and now I'm doing the same with my '87 IROC. However the IROC is being managed by a FAST engine management system with new relays running the stock fans.
Old Jun 12, 2020 | 09:41 AM
Re: Help with fans
Yeah the previous owner TRASHED the wiring. I repared and replaced most of it so far. This coolingfan is the last to do before saftey.
Old Jul 23, 2020 | 09:26 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Help with fans
xxx3man`
Aug 21, 2018 06:19 PM
Manic Z
Mar 9, 2018 07:42 AM
MeenZ28
Apr 15, 2013 12:22 AM
soarestransam
Feb 3, 2012 09:44 AM
89 305 Formula
May 13, 2004 11:06 AM
