L-69 Fan Mounting?...
Old Aug 7, 2020 | 12:17 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
I know the top bolts to the radiator bracket/shroud. What do the bottom holes bolt to?...
Old Aug 7, 2020 | 05:23 AM
Re: L-69 Fan Mounting?...
A more or less flat plastic piece that bolts to the bottom of the core support. 2 bolts at the bottom if memory serves, and 2 bolts that hold the fan to it.
Old Aug 7, 2020 | 06:59 AM
T.L.'s Avatar
Great, I don't have that piece. . Any idea where I can get one?...
Old Aug 7, 2020 | 07:28 AM
Drew's Avatar
Any thirdgen with a single fan... V6, TBI, anything that didn't have duals.
Old Aug 7, 2020 | 07:37 AM
T.L.'s Avatar
Thanks, Drew. I don't know what happened to the one from my parts car. I can't imagine I would have thrown it away...
Old Aug 7, 2020 | 10:19 AM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
pretty common piece at most wreckers
Old Aug 21, 2020 | 09:36 PM
T.L.'s Avatar
Okay, I got a lower bracket. Is there supposed to be some kind of spacers that go between the fan and lower bracket?
It does not line up with the top bracket/shroud...
Old Sep 7, 2020 | 08:49 PM
T.L.'s Avatar
Guys, I need HELP. I just cannot see how the bottom of this fan is supposed to mount (I have he lower bracket now).
I'm putting an electric fan from a '84 L-69 equipped thirdgen into a '83 Firebird that never had an electric fan. What I really need are some pictures so I can see what I'm missing or doing wrong...
Old Sep 8, 2020 | 07:15 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
if memory serves, a pair of u-nuts attach to the bottom fan bracket piece and the bolts go through the bottom radiator tray into it. it sits inside, on the radiator side, of the metal lip of the tray.
I can confirm with a pic later today if needed.
Old Sep 8, 2020 | 02:24 PM
gt4373's Avatar
Transmission: 5-Speed Manual
What naf Said,Not The Greatest Pics,Hard To Get A Cam In There It's Held On To The Bottom Bracket With Extruded U Nuts.
Old Sep 8, 2020 | 04:39 PM
T.L.'s Avatar
Thanks for the pics. Are the power steering line clips mounting to the same holes as the lower fan bracket?...
Old Sep 9, 2020 | 10:25 PM
gt4373's Avatar
No They Have Their Own Bracket.
Old Sep 9, 2020 | 11:35 PM
T.L.'s Avatar
Wow, I don't have those brackets. I was trying to mount it in the same holes that the lower fan bracket bolts to (doh!!!)...
Old Sep 10, 2020 | 06:48 AM
Drew's Avatar
Later cars don't have additional brackets for the steering cooler, they just double up with the lower fan mount bolts.
Old Sep 13, 2020 | 08:16 PM
T.L.'s Avatar
Okay, I got the fan mounted. Thanks for all the advice. Crazy how something so simple can be so confusing.
The confusion came from not having the bottom fan bracket, and from the mounting of the power steering cooling lines. Does anyone here happen to have an extra pair of those early mounting brackets for the cooling lines? It's really a pain trying to mount them through the same holes as the fan bracket. Right now I'm temporarily using zip-ties...
Old Sep 14, 2020 | 09:00 AM
naf's Avatar
naf
you can pick up some similar mounting brackets for the cooler lines from a hardware store and make them work.I used them for plug wire holders once:
https://www.thirdgen.org/forums/atta...ugwireloom.jpg
Old Sep 14, 2020 | 09:25 AM
T.L.'s Avatar
Yeah, I have those already. I'm talking about the other funny-shaped ones in the pictures above...
Old Sep 16, 2020 | 05:20 PM
T.L.'s Avatar
So I guess no one has any of those. They must be rare...
Old Sep 17, 2020 | 10:08 AM
naf's Avatar
naf
at this day and age it may be difficult to find some, best bet is to post here in the parts wanted section.
Ozz1967
Sep 23, 2014 02:53 PM
napalm368
Jul 19, 2012 11:14 PM
Beartracks
Apr 19, 2004 09:16 AM
