Should there be a hose clamp here?
Old Jan 30, 2022 | 03:15 AM
HeavyChevy383's Avatar
The hose that connects to my coolant reservoir seems to leak instantly. I originally thought it was my tank, ordered a new one but now found its actually coming from the hose.
https://imgur.com/a/TAHTBW0
^pic attached.
Its not fully connected in the picture but i was wondering if there is supposed to be a hose clamp there or something? It's leaking when car is off.
Old Jan 30, 2022 | 07:35 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Re: Should there be a hose clamp here?
i believe one of the small coloured spring-like clamp not a regular style hose clamp
Old Jan 30, 2022 | 10:06 AM
shaynecastongua's Avatar
Car: 1985 Trans Am
Engine: Chevy 355
Transmission: T5 NWC
When the car is off the coolant cooling down creates a vacuum that pulls from the overflow tank which can create some pressure on that connection. Mine came with a spring clamp but I ditched it for a regular hose clamp. Either works, just don't tighten the hose clamp like crazy if you use the regular style.
Old Jan 30, 2022 | 11:56 AM
gt4373's Avatar
Transmission: 5-Speed Manual
It Uses The Same Type Clamp As The Opposite End
apie2546
Oct 16, 2014 05:53 PM
QuickStyle
Mar 8, 2013 08:12 PM
Omega
Aug 6, 2010 02:35 PM
91Z28-350
Jul 26, 2005 12:17 AM
jrg77
Aug 26, 2004 11:18 PM
