Overflow tube leaking coolant? Everything's new
Old Feb 11, 2022 | 04:11 PM
HeavyChevy383's Avatar
I just replaced coolant reservoir, new hose, and new clamps and the hose is still leaking from the connection point of the hose to the overflow tank. This happens when the car is off. Any ideas? Could it be a bad headgasket or radiator cap or air in cooling system? How could I check
Old Feb 11, 2022 | 04:18 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Overflow tube leaking coolant? Everything's new
Are you sure it's leaking from there, or leaking from radiator side and running down the outside of the hose to the tank where it drips to the ground? What clamps you using?
Old Feb 11, 2022 | 04:24 PM
yes I am certain it's coming from there. I am using some plumber clamps right now because no parts store near me has the size I need. I'm not sure if the clamp is the issue though as before there was no clamp even on that side and it didn't leak. It just started leaking after temperatures got below freezing for some reason.
Old Feb 11, 2022 | 04:45 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
What kind of hose and what is the inside diameter? Is your coolant reservoir vented?
At the end of the day this is all pretty simple. You got a nipple with a certain OD, and need a hose of a proper ID, and a clamp suitable for the OD of the hose. Like your actual hoes, not the old hoes that you threw away. But a clamp can't make up for bad fitting hose (over sized) -- the hose has to be right.
Worm screw clamps do not provide uniform clamping force around the circle. That's why spring clamps are used. But the spring clamps are only suitable for certain range of hose OD. Your replacement hose is not necessarily the same OD as the stock hose, so you need a spring clamp for your hose. Unfortunately it's a bit of trial and error because you don't have access to the part drawings with the specs.
Old Feb 11, 2022 | 04:55 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
There's something incredibly wrong with our society when state-of-the-art software prefers spelling of hoes over hose.
Old Feb 14, 2022 | 02:00 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Maybe
1. The hose is too large. If it easily slipped on maybe you need the next smaller size.
2. Clamp is not tight enough...I usually go with a screwdriver till it stops...let it heat up / cycle, then come back a few weeks later, and f leaking give it a litle more tuturns after the hose gets adjusted / aged
3. Maybe its too tight and cracked the plastic tank
Old Feb 14, 2022 | 06:55 PM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
I had the same problem on my 88 with a new GM coolant reservoir. I replaced it with another new GM one and guess what: That also leaked. The hose was the correct size. I ended up using two hose clamps next to each other and filed the tank plug a little bit round. That did the trick for me and it hasn't leaked for three years (fingers crossed).
Old Feb 14, 2022 | 08:27 PM
Originally Posted by 1989karr
Maybe
Okay so I just bought a new hose and it fits much better and more snug. We will see how it holds up though
I will try that next if this new hose I just got doesn't work! Thank you!
Old Feb 14, 2022 | 08:34 PM
NoEmissions84TA's Avatar
A better mousetrap:
stevek
May 8, 2010 01:11 PM
noisyme
Sep 27, 2006 09:44 AM
91ChevyRS
Dec 12, 2005 12:07 PM
dyeinbreed
Mar 24, 2003 03:40 PM
bklucas12
Jan 16, 2002 05:37 PM
