SEQUENTIAL injection without cam sensor ?
Old Aug 5, 2003 | 11:32 AM
Hasselhof's Avatar
Car: 1988 Trans AM Gta
Engine: 6.0 Liter TPI
Transmission: TH700r4
Hi I have been reading up on Dfi systems. And the accel dfi 7 uses a dual sync distributor to run sequential injection....how is it possible to do that without a cam sensor ?
please educate me
Old Aug 5, 2003 | 12:16 PM
aDFIguy's Avatar
Car: GTP
Engine: L67
In the absence of a cam signal, the DFI operates in a "random sequential" mode. It follows the firing order sequentially, based on a known crank signal pattern.
Old Aug 5, 2003 | 12:44 PM
Hasselhof's Avatar
interesting!
It dosent sound very accurate..is there much advantage to doing that over normal batch fire ?
thanks
Old Aug 6, 2003 | 05:55 AM
aDFIguy's Avatar
Car: GTP
Engine: L67
It's not recommended that you run this way intentionally. However, you still get the benefits of sequential: less fuel rail transients, individual cylinder fuel control...etc. If you are thinking about running sequential, definitely get the Dual Sync (or some other) sequential distributor.
Old Aug 6, 2003 | 09:08 AM
Hasselhof's Avatar
wouldent a system like electromotive TEC3 be a better option since it have "real" sequential. With a high resolution ignition and a cam sensor. Their system looks very much like LS1 teknology. Not many people uses their system is their something about the accel that makes it the most desirable ?
thanks!
Old Aug 6, 2003 | 02:38 PM
aDFIguy's Avatar
Car: GTP
Engine: L67
I don't know much about the tec3. However, I don't think older tec units could use stock cam/crank signals, you had to bolt on their crank trigger contraption. Don't think this has changed w/tec3, but I haven't used one yet either.
The DFI unit is software-configurable for many types of cam/crank/spout combinations. Either pick a predefined combination (Chevy HEI, Buick GN Coil Pack, Ford EDIS...etc), or select the cam/crank/spout trigger edges and signal levels that you want.
You misunderstand about the random sequential stuff. It is more like a failure mode such that when you are running "true" sequential, and you lose your cam signal, your motor doesn't quit. You can still drive home. The dual-sync distributor gives both crank and cam position signals to provide "true" sequential operation.
Old Aug 6, 2003 | 07:32 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Originally posted by aDFIguy
"random sequential"
Must be one of em new fangled engineering terms. LOL
Old Aug 6, 2003 | 07:56 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Technically the second pick-up in the dual pick-up distributer would be a cam sensor, it just does read the cam directly, but a part driven off the cam, like the newer s-series trucks, don't know what year they started with it, but I do know in '99 it has a cam sensor used this way.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
z28addict8490
Sep 5, 2015 03:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Thirim
Aug 13, 2015 03:09 PM
