Is there a way to test an ECM??
Old Sep 4, 2003 | 09:31 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
After doing a TBI tp TPI swap i got the car to run but it wasn't running just right.. So i let it set for about 2 weeks and went back to work on it again.... Now i can't get it started even. I can only get the SES light to blink once and then it goes out so i couldn't pull any codes off of it. And now i checked the injectors with a noid light and i am not getting any injector pulse. I did before cause it was running for about 2 weeks. What can it be?? A bad ground maybe???.... Should i just get a new ECM? ....OR is there a way i can check to see if the one i have (7165) is any good?..... Any suggestions would be greatly appreciated...
Old Sep 5, 2003 | 07:20 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Well I have an article written by GM about checking ECMs. Give me a little time to find it.
Old Sep 5, 2003 | 08:11 PM
Car: 92'Camaro RS
Engine: a loud one
cool...thanks for the assistance Z
Old Sep 5, 2003 | 08:17 PM
armac's Avatar
Car: 83 ta
gm ecm test is just tapping on the ecm and see if any things happens. the older ecm use to have a problem with loose connections. it is called the "tap" test
Old Sep 6, 2003 | 08:22 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Some parts houses will rent / loan out a break out box.
This allows you to check out everything but the ecm.
Only other option is building an ecm test bench or finding someone that has one that supports your ecm.
Old Sep 6, 2003 | 09:48 PM
Car: 92'Camaro RS
Engine: a loud one
I decided to order another ECM ,should be in tuesday..If that doesn't work i guess i'll just buy a painless harness and replace this one. Got to be one of the two causing my problems.
Old Sep 8, 2003 | 05:47 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I need you to give me more time, I'm still looking in my books.
BTW I had the same problem and it was bad ground.
Old Sep 8, 2003 | 08:07 PM
Car: 92'Camaro RS
Engine: a loud one
Okay z........ i won't get one yet......i wasn't trying to rush you...just was kinda thinking out loud i guess. Isn't there only 5 grounds to the ECM?..... Or are you saying it could be a ground on something else.... Cause i know when i put the harness in i grounded 5 wires off the ECM and i even went back and cleaned them real good and still ended up with the same results. Thanks
Old Sep 13, 2003 | 06:14 PM
Car: 92'Camaro RS
Engine: a loud one
Wasn't the ECM that was bad...How about the brand new chip i just bought
KCG
Jun 24, 2020 04:33 AM
gta892000
Aug 11, 2019 11:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
eustodp
Sep 20, 2015 05:09 PM
