ALDL help
Car: 89 camaro
Engine: 305 tbi
Transmission: 700 r-4
ALDL help
When you place a wire in the a and b slots of the aldl to check for codes. What does it mean if the light keeps repeating 12 over and over again? I know that it is supposed to flash three times but mine keeps flashing over and over. I think that this topic was posted some time back and if it was please refer me to it.
Car: check
Engine: check
Transmission: check
Everything is OK. AFAIK the ECM will keep flashing the codes out as long as A & B are shorted and the ignition is on (engine off). Not sure where the 3 times came from but I've also heard that. Maybe it is with CCC setups.
RBob.
RBob.
