Ford VS GM injectors??
Old Dec 20, 2006 | 12:49 AM
Dave Farr's Avatar
Hope this is a relevant question to this particular forum. Have a 89 truck puting down 250 hp at the rear wheels and soon will be rebuilding a slightly warmer engine for it. Currently using Ford yellowtops which are 19pph which I think is around 22pph at 45psi and work quite well. I was thinking of using the 24pph bluetops for the next engine which may be overkill but I already have them but haven't sent them out to be cleaned and flowed yet. The question is- the Bosch/Ford injectors are pretty good and likely better than GM put in the 90's, I'm wondering if a set of LS1 takeoffs would be a clear upgrade being a newer generation and if so- are they a direct bolt in for TPI rails and harness.
Old Jan 10, 2007 | 10:15 PM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
I don't have a specific answer but I do know that the electrical plugs are different on some of the new injectors. You might be able to determine an answer by looking at injector specs. Try fiveomotorsport.com.
I have also read that some of the newer disigns have a better spray pattern, can't confirm that personally though. What I wonder is if you dyno tested the injectors is there a measureable difference? I'm guessing that it wouldn't register a difference on the dyno.
Good luck
Old Jan 12, 2007 | 08:14 PM
Dave Farr's Avatar
Sounds like your right- all the feedback I have recieved indicates that the injectors are a direct replacement and are marginally better but there is no reason to replace the Ford bluetops.
Old Jan 14, 2007 | 10:18 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
No, the LS1 injectors are too short, they are about 0.12" shorter than the GM factory injectors. Use the Ford Racing injectors. If you got a 305, then run the 19s with an AFPR.
Old Jan 14, 2007 | 10:58 PM
firstfirebird's Avatar
Not that I know anything, but everything I have read says the blue tops are underrated. Just got a set myself for a completely different project, but I can let you know how they work pretty soon. The only problem is I'm going to run out of injector at 225hp on my v6, so will be searching for some larger ones soon...
Old Jan 14, 2007 | 11:12 PM
Transmission: TH350
Here is a link with the math formulas for calculating desired injectors.
http://www.rceng.com/technical.htm
Old Jan 14, 2007 | 11:15 PM
Thanx atomic, that went right into my favorites!
Old Jan 15, 2007 | 08:17 PM
Dave Farr's Avatar
Looks like I keep the bluetops, if they are cleaned and matched- what would be the difference between these -history unknown- and the Ford racing units?
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
92-Formula
Dec 12, 2015 10:34 PM
webeeZ28
Sep 14, 2015 12:00 PM
