What setup is best for me?
Old Jul 1, 2007 | 04:49 AM
Kurt04's Avatar
Well, I no longer have a Third Gen anymore but this is the only place I know of that has a broad range of EFI knowledge. After I return from Iraq I will be putting a SBC into my '92 S-10, this is going to be my daily driver, which is why I am now leaning towards EFI.
I am open to any and all suggestions, because I am clueless as to what setup is best for me. I have 8 months left to plan out the build and gain some EFI knowledge.
Only real specfics are that I can learn tune it myself and it is reliable.
P.S. Wasn't sure if this should go here or "Alternative Port EFI Intakes"
Old Jul 1, 2007 | 03:55 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: What setup is best for me?
the factory GM ECMs can be tuned, there is a steep learning curve but the factory systems have a lot to offer. to me one of the biggest things is the fact you can get most any ECM from a wrecking yard when ever you need to.
you can go with TBI or TPI.
there are a few choices of ECMs you can use.
the 7730 which was used in the 90~92 TPI thirdgens which is a speed density system.
a few different ECMs if you want to go with TBI, one or 2 of which can also run a TPI motor.
there are some that can control an electronic shift transmission.
the 7749 which was used in the Syclone if you want to turbo charge it.
or even one of the newer OBD2 computers.
you may want to contact S10Wildside for info on a wiring harness, & he can probably offer some ideals on which way to go.
for tuning a factory GM ECM, you can start here.
https://www.thirdgen.org/forums/diy-...uide-book.html
there is a ton of reading, so you may want to wait until you decide if you want to go with a factory ECM & which one you want to use.
stay safe & thank you
Old Jul 2, 2007 | 07:35 AM
Kurt04's Avatar
So is a factory ECM would be much easier than a standalone unit?
Old Jul 3, 2007 | 01:28 AM
DENN_SHAH's Avatar
i have never messed with any of the after market systems, so i know nothing about them, i can't tell you if one is easier than the other, hopefully someone who has done both will jump in. my understanding is the after market systems don't do as much as the factory systems can.
i do burn my own chips for the 92 camaro TPI system i have in my car.
it took me some time to learn how to do it. there is still a lot i don't know, sometimes i enjoy it, other times it drives me nuts.
something i for got to mention, there is also the EBL for TBI systems.
it seems everyone who has it loves, i have heard nothing bad about it.
Old Jul 3, 2007 | 09:01 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
In my opinion....
Either go with an OBD -II computer and an electronic trans or an aftermarket. The aftermarket computers do everything the stock do and more. However, I am not aware of any that will run an electronic transmission (although the megasquirt will as soon as the gpio board is released. They are writing code for the 460le as a start)
I have never programmed a stock GM OBD-II computer. However, I have done a complete wiring harness for my computer, and tuned it. I can tell you that it is not as bad as you may think. The megasquirt and the SBC go together very well. In fact, the megasquirt comes preloaded with a fuel map for a TPI 350. It is also set up to run all gm sensors by default. I am using the stock distributor and 8 pin module for timing control.
Old Jul 10, 2007 | 08:08 AM
Kurt04's Avatar
Well I have been doing alot of research. I'm leaning towards 730 or 749 ECU, Moate's Ostrich and prolly tune with TunerPro RT.
Prolly have S10Wildside build me a custom harness to make things simpler.
This will be powering a Miniram'd 383.
Old Jul 17, 2007 | 11:17 PM
jay29's Avatar
From: Houston is where my address is Baghdad is where I work
Car: !988 Iroc-z
Engine: 355 L98 Few nice Mods
Transmission: 700R4 with 2400 stall
Axle/Gears: 373
A little off subject where are you at in Baghdad? I'm in the I.Z.
Old Jul 17, 2007 | 11:39 PM
Kurt04's Avatar
I'm on Camp Victory.
Old Jul 21, 2007 | 02:33 AM
Kurt04's Avatar
Are there anythings I should take into consideration if go with a single-plane EFI manifold instead of a Miniram, as far as tuning is conserned?
Old Jul 21, 2007 | 07:01 AM
jay29's Avatar
Car: !988 Iroc-z
Axle/Gears: 373
The big PX Youve got it made We've got a SHi##$ PX and get Rockets shoved up our A$$ all the time.
Old Jul 21, 2007 | 07:11 AM
Kurt04's Avatar
lol We get rockets/motars sometimes to.
Old Jul 22, 2007 | 09:08 AM
jay29's Avatar
Car: !988 Iroc-z
Axle/Gears: 373
They quit shooting the mortors at us they figured out how to use the good stuff.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
