ECM Question.
Old Aug 9, 2007 | 06:50 PM
RocsRose86's Avatar
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
ECM Question.
Okay I have spark and my car spins over, but will not run. I have a 5.7ltr Iroc, could it be my ECM? I really need some help here guys. Does anyone think it may be my ECM? I really hope it isnt my computer, cause if I cant get it going then......... carb is gonna be installed.(dont want that) I have a spare Edlebrock Torker series intake manifold and a 650 holley! Thanks in advance for all your help.
Old Aug 9, 2007 | 08:35 PM
AC's Avatar
AC
Car: Used to drive a camaro
Re: ECM Question.
HOLY CAPS CRAP BATMAN!!!. I dont' even know how you got the font that large. Any way, I'm fighting a simliar issue on my EFI setup. The ECM is only 1 possible culprit. From what I've been learning I'd start with the dizzy to make sure your getting voltage where it belongs and all your grounds are good. Also test to see if your dizzy is sending ref pulses at all to your ecm. Look in my thread to see the cr*p I'm trying to get through.https://www.thirdgen.org/forums/diy-...ml#post3422844
Old Aug 12, 2007 | 08:07 PM
RocsRose86's Avatar
Re: ECM Question.
I have my injectors pulsing. The very large letering was a cry for some abundant help. I used a test light @ the obdII plug and I dont get the 1.5 volts.
Old Aug 12, 2007 | 08:21 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: ECM Question.
Your injectors are pulsing and you have spark? Try starting it with a bit of ether.
It sounds like it might be a fuel pressure issue.
Old Aug 13, 2007 | 07:59 PM
RocsRose86's Avatar
Re: ECM Question.
I have no inj pulse but has spark! sorry wrong info b4!
Last edited by RocsRose86; Aug 13, 2007 at 08:03 PM. Reason: Automerged Doublepost
Old Aug 13, 2007 | 08:08 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: ECM Question.
I take it you made a engine swap into the 86 and are trying to use the stock ECM. Well did you change the chip out to run your 350 ???? If the 305 chip is still in there it may be your problem and this is a guess.
Old Aug 13, 2007 | 09:41 PM
Toehead's Avatar
Re: ECM Question.
The computer is looking for reference pulses from the distributor to give it an RPM signal. Check the 4 pin connector at the back of the distributor and make sure it isnt loose. The modul will still spark even with the computer disconnected.
The computer also will not fire the injectors unless it gets the rpm signal.
Old Aug 16, 2007 | 06:37 PM
RocsRose86's Avatar
Re: ECM Question.
So i should check the rpm signal/the 4 pin connector @ the back of the distributor. I looked the two wires in the front are connected one green and one black, which are seperate wired connections and the two in the back which is a single connector. what about the 1.5 volts at the obd II connection?
Old Aug 16, 2007 | 07:01 PM
MIKE1988GTA's Avatar
Car: 1988 GTA
Engine: 5.7v8
Re: ECM Question.
I had the same problem. I read about a fuse next to the battery.Checked for it and It was blown,20 amp fuse had me down for there weeks. Check it out, it might be your problem too.
Old Aug 17, 2007 | 06:35 PM
RocsRose86's Avatar
Re: ECM Question.
20 amp fuse still good. all grounds are hooked up, i think i may try scuffing the int. manny to maybe get an even better ground. what about the distributor wires being crossed? i think i may just buy another computer, or go carb(which i really dont wanna do cause my motor looks is so hott with my tuned port.) PLEZ guys I wanna stay tuned port injected.
Old Aug 26, 2007 | 07:03 PM
RocsRose86's Avatar
Re: ECM Question.
So I take it that know one has any idea or any other suggestions? Plez if i dont get it running again i an gonna sell it. Then i guess i will pull the 90 irocz out of the garage. the runs no where near what my 86 ran.(86=13.20 in a 1/4) (90=15.40 in a 1/4) plus i was trying to keep the 90 all original and bone stock. So fellas as much input as possible PLEZ!!
Thanx Mark
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
