Does any one no how to remove the limiter on my 92 camaro tbi rs ?
Old Aug 19, 2007 | 03:21 PM
alexc7802's Avatar
Yesterday I was going down teh highway at 110 mph and all of a sudden my cars rmps dropped straight back down to 1100. Does any one no of a chip to override the govenor or simply remove it. thanks
Old Aug 19, 2007 | 04:05 PM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
Re: Does any one no how to remove the limiter on my 92 camaro tbi rs ?
you can get a new prom burned without the limiter. The limiter is put there based on tire speed rating so if you delete the limiter, make sure you have tires rated for higher speeds. With a 305 I'm sure H rated tires would be sufficient.
Or the hack way of disconnecting the VSS, which will not allow the computer to know the speed, but unfortunately you will lose your speedo too, so that sucks.
And if anyone tries to tell you that you can bounce off the limiter 6 or 7 times and burn out that circuit, dont listen to them, thats bs, i know cause my 90 Bird had a limiter and I'd be willing to bet I bounced it off the limiter at least 100 times and its never stopped working.
Old Aug 19, 2007 | 04:17 PM
alexc7802's Avatar
thank you, where can i get a new prom burnt?
Old Aug 19, 2007 | 04:39 PM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
not sure if there are any sponsors here from chip burning, but you could try doing a web search for pcm chip burning, I do know of one place I think burns the chips, its www.pcmforless.com I think thats the address anyway. Here is the page you want:
http://www.pcmforless.com/index.php?...d=44&Itemid=40
Old Aug 20, 2007 | 02:30 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
http://www.tbichips.com/
http://www.fastchip.com/
Old Aug 20, 2007 | 09:17 AM
alexc7802's Avatar
thanks
Old Aug 21, 2007 | 08:20 AM
alexc7802's Avatar
are there any alternatives besides chip burning to do this? I no that superchips does not make a model for 92 camaros but are there any other makers out there?
Old Aug 21, 2007 | 10:18 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
No. It is either that or put a disconnect switch on the VSS, which causes its own problems.
You could also get the chip burning equipment and do it yourself.
Old Aug 21, 2007 | 01:20 PM
cam92rs's Avatar
Car: 25th anniv. camaro
Engine: 305 tbi
ive had a switch hooked up to my vss for about a year now. i havnt had any problems.....the only things i know about it is that, when you turn the vss off. your rpms go up a couple hundred. while having it off for a minute or so, the check engine light comes on. the computer is on the passenger side under the dash.. i think the vss is the brown wire with black stripe? im not even half sure on that. lol. been soo long since ive done it.
but if you remove the vss permenantly. im sure you will have problems.
if hooked to a switch. you will have to shift to over drive, back off the throttle until it shifts then give it more gas slowly. our cars dont have the WOT d to OD capabilities.
Old Aug 21, 2007 | 01:37 PM
Toehead's Avatar
Yes, because the torque convertor unlocks. It is not very good for your transmission, because at that speed the transmission will have some serious convertor slip and it will generate a boatload of heat.
Old Aug 21, 2007 | 02:35 PM
camaro91boy's Avatar
Car: 95 z28 camaro or 92 k5 Blazer
Engine: LT-1 fo the Z. vortec fo K-5
Transmission: 4L60E=Z junkR4=K-5
Axle/Gears: 3.43=Z / 3.73=Blazer
i thought so when i had my 145 speedometer it didn't hold me back but when i fried it i replaced it with the 0-110 out of a v-6 and now it stops me at 100 so i got currious and unpluggeed the wire off of the tranny and i could go as fast as i could my car even shifted once more around 100. thats cool now i know i wasn't actually hurting the car.
Old Aug 21, 2007 | 04:05 PM
3rdGenWillie's Avatar
Car: 92 Lo3 RS
Engine: 305 roller tbi
Transmission: t-5
Axle/Gears: 3.08 open
What about a t5 manual car, hitting speed limiter is like hitting brick wall
Old Aug 22, 2007 | 07:18 AM
alexc7802's Avatar
camaro91boy are you saying that when you had your 145 mpd speedo that your car did not hold you back?
Old Aug 22, 2007 | 02:30 PM
more info please i want to know how and what wire exactly and will it let me use my speedometer or will it just shut off all my spedo sensors information. basicallty i want to know if i can turn it on and race rice burners with no problems this getting to 100 and redlineing is crap. ???????
Old Aug 22, 2007 | 03:01 PM
yeah instead of stopping at 100 it went all the way to 145 and pegged thats when i fried it and stripped the gear on the speedosensor but when i replaced all of it it regulated it at 100.
Old Aug 22, 2007 | 03:30 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Cluster has no bearing on the limiter. you either had a screwed up 145mph cluster or a wiring or gear issue.
Old Aug 22, 2007 | 05:48 PM
o.k. so it did i said it fried when it went over 145. it has never done it since.
Old Aug 23, 2007 | 01:59 PM
Car: 92 Lo3 RS
Transmission: t-5
So what actually is problem when speedo and Odo die. everything else in cluster works still, did i miss blown fuse?
Old Aug 23, 2007 | 09:44 PM
3rdgenwillie
i just fixed this problem. when you drive dose your car ever top out? if not and it feels realy fast and then shifts, i had the same problem. forhand warrnig when you fix the speedo. the speed reg will kick back in. all you have to do is take off the sensor on the tranny that looks like a big circle. (before you get anew one wiggle the shaft up and down if it moves more than a1/8 in back and forth you will need a new one.) get a new one swap over the big cone shaped gear ( if gear looks a bit worn off go to any local tranny shop to get a new one) and put it back in drive down the road a couple times and the speedo will work again.
Old Aug 23, 2007 | 11:35 PM
spina74's Avatar
Car: 01 Trans Am Ws6, 92 Camaro Rs
Engine: 6.0, 305
Transmission: T56,700R4
Axle/Gears: 3.90 9", 2.73 10 bolt
I know if you hook up an msd 6al box it over-rides the limiter, It did with my 92 RS before I swapped it over to a carb.
Old Aug 24, 2007 | 09:51 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
That is the biggest line of BS that I have heard. A look into the code side of the ECM will explain why. The speed limiter is NOT an ignition kill. It is a fuel kill. When the car reaches 110 mph, it shuts off the fuel injectors and fuel pump relay, until the car drops below 108 mph.
Old Aug 24, 2007 | 02:34 PM
dose anyone know if you can remove the speedregulator program off of the computer using a genisis system?
Old Aug 24, 2007 | 03:10 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
want to do something stupid like this, on the cheap? heres two ways.
way1:
simple on/off switch.
cut the sensor wire coming from your VSS (one is ground, other is the sensor)... on electronic speedo cars, its on the transmission.. on cable speedo cars, its in the cluster.
wire the switch in the cut wires.
now go floor your car... and when you get going fast and have it floored, flip the switch.... dont worry, you'll have plenty of time to flip it, since if you need to do this, you have a stock motor anyway. LOL!!! (i joke i joke)
when you flip it, if you have an electric speedo, it will goto zero. this is moot as your speedo only reads to 110 anyway.
if you have a mechanical speedo.. it still works.... well, it will eventually break if you peg it out alot.. but thats doubtful.
as for the torque converter unlocking... its always unlocked at WOT anyway.. this is a moot issue too. BUUUUUT
say you wanted the TQ converter clutch locked for thehell of it.
make the switch a DPDT switch.
now when you turn off the VSS, have it put power in to the TQ converter lockup wire.... now you have your locked trans, and you can go as fast as you have power for.
all that said.. its a stupid idea. if you choose to do this, i thank you for your choice of leaving the gene pool. thankfully most of you are young and without kids, so there wont be any orphans, but try not to take anyone else out with you... thanks.
Old Aug 24, 2007 | 10:07 PM
[quote=MrDude_1;3443239]want to do something stupid like this, on the cheap? heres two ways.
way1:
is there a way to do this with out killing your speedometer?
and can you answer my last question? i have a genysis avalible for a short time and want to do it fast.
Old Aug 25, 2007 | 11:24 PM
Kevin91Z's Avatar
There are only two ways to do this. Change the prom in the computer, or disable the speedometer input to the computer with a switch.
I dont know what a genysis or genisis is.
Old Aug 26, 2007 | 08:48 AM
A genysis? the $5000 computer usually found in mechanics shops that plug into an obd1 or obd2 port in your car and tells you exactly what is wrong with your car.
i figure that if you can change other portions of the progamming with it, i wonder if i could remove the speedlimiter with it and still keep my speedometer.
Old Aug 26, 2007 | 10:01 AM
Toehead's Avatar
Not with obd-I. obd-I isn't flashable like obd-II. You need to physically remove the chip, use a UV eraser to erase it, and then reprogram it.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
3rdgenparts
Aug 8, 2015 07:09 PM
