Disabling Oil Temp Sensor in Tuner Pro RT using Axcn bin
Old Dec 24, 2008 | 10:26 PM
91350rs's Avatar
Car: 91 camaro RS
Engine: superchargered 350
Transmission: t56
Axle/Gears: 4.10
RBob has tried to help me with this but I am not really that knowledgable yet with tuning GM's, much yet using Tuner Pro.
I know there are two settings/flags that you must disable. The high and low oil temp sensors......So I am assuming that they are in the flags/switches section of tuner pro rt.
RBob said that the oil temperature sensors are malfunction word 4, bits 1 & 7. Oil temp high & low.
But anyways, I open tuner pro and i open the acxn bin with the $8d mask. The program shows 3 boxes on the left of the page.......constants/scalers, flags/switches, and tables/functions.
Now, I'm assuming that this malfunction word 4 is somewhere in the flags/switches section, i just cant find anything that says malfunction word 4 or high and low oil temp settings to uncheck/disable.
i just see stuff like "switch 16 (VATS TCC-R 4th-NO VATS OLP) - Bit 7- B7", etc.....
so out of that whole list of flags/switches, which is for the oil temp sensor?
is it located somewhere actually in the hex code?
hopefully my question is understood and makes sense.
thanks
Old Dec 27, 2008 | 11:29 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Disabling Oil Temp Sensor in Tuner Pro RT using Axcn bin
Which XDF file are you using?
The switches/flags section is the correct sention to find the check boxes for the oil temperature DTCs.
RBob.
Old Dec 27, 2008 | 11:51 AM
91350rs's Avatar
Car: 91 camaro RS
Transmission: t56
Axle/Gears: 4.10
RBob.
$8d bin definition axcn bin.
hopefully you can help me find exactly which ones to disable.
thanks
Old Dec 27, 2008 | 01:53 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
What I was asking about the XDF file is which one is it. These files are created by different people and vary from one to another. So what is available and how the parameters are labeled vary. There are probably 4 to 6 different ones around just for $8D.
RBob.
Old Dec 27, 2008 | 09:14 PM
91350rs's Avatar
Car: 91 camaro RS
Transmission: t56
Axle/Gears: 4.10
RBob.
Moates.net.
Went to bin definitions, then to gm, then to the 8d
Is there one that you reccommend?
Old Dec 28, 2008 | 10:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There are in there:
Switch 24C Error Code Masks (52-63) - Bit 7 - 52
Switch 24C Error Code Masks (52-63) - Bit 1 - 62
RBob.
Old Dec 28, 2008 | 12:01 PM
91350rs's Avatar
Car: 91 camaro RS
Transmission: t56
Axle/Gears: 4.10
There are in there:
RBob.
you are awsome man!
thanks for the help!!
Old Mar 4, 2010 | 12:45 PM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
in tunerpro do you click "set" to enable or disable these codes? Ie should it say "set" or "not set" to disable the settings.
Old Mar 4, 2010 | 01:05 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Un-check the box to disable.
RBob.
Old Mar 4, 2010 | 01:13 PM
TG Goose's Avatar
Engine: 355 SD TPI
perfect, that makes sense, but its one of those things you want to double check on.
Bstrang6
Sep 8, 2015 04:29 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
355tpipickup
Aug 19, 2015 10:02 PM
bamaboy0323
Aug 15, 2015 07:20 AM
