Swapping an ecm in an LG4?
Old Feb 3, 2010 | 03:29 PM
warlord's Avatar
Car: 1983 Trans Am t-top
Engine: 305 4bbl carb (vin code H)
Transmission: 4 speed automatic
I was just wondering is it possible to swap the ecm in my 83 trans am LG4 to a later year one? is there any benefit? as i know it is a good swap for fuel injected cars.
I also am thinking about swapping my mechanical speedo to an electronic one, so maybe do both?
Old Apr 8, 2010 | 08:26 AM
86TA4SALE's Avatar
Car: 1986 Trans Am
Engine: LG4 305 carb
Transmission: auto 700R4
Axle/Gears: 2.73 open
Re: Swapping an ecm in an LG4?
I'm curious about this too. I have heard of LG4 guys putting in an L69 ECM, especially if you swap to a hotter cam. The L69 would already be set up for something like this.
~Matt
Old Apr 13, 2010 | 10:50 PM
Jazz T/A's Avatar
Car: 82 Trans Am, 68 El Co, 84 K5
Engine: Carb 350, Carb 327, 6.2 Diesel
Transmission: Borg-Warner T10, TH-350, 700R4
Axle/Gears: 3.23, stock 10 bolt, 3.73
any one have more info on this im about to drop in a hotter cam and wouldn't mind doing this too.
Old May 10, 2010 | 07:15 AM
86TA4SALE's Avatar
Car: 1986 Trans Am
bump
Old Nov 7, 2011 | 02:03 PM
82LG4BelAir57's Avatar
I'm looking for info on this as well, I have the L69 ECM, I just read abbout the ESC module, and wondering if my LG4 harness has provisions for it... both are '84s
Old Nov 11, 2011 | 10:26 AM
Ronny's Avatar
My first swap was from a 84 vette ECU to a 87-89 truck ECU(7747). Was the truck ECU superior? I doubt it. the speed of the ECU was most likely similar. I needed to because the 84 was not hacked and not supported. My car was sig modified. next swap was to EBL. Much faster processor, expanded tables, etc, etc. Now the swap you may want consider is EBL or a late model PCM from a mid 90's truck I believe. They are faster and supported. See threads by Dimented on use of PCM. Or go aftermarket like EBL MS or others.
Old Nov 11, 2011 | 11:26 AM
I read about that, but didn't want to get too involved, my junk yard actually had a car that I was able to acquire the Baro sens, ESC and KS, and wiring from, though i've yet to hook it up.
Would the newer (90's truck) PCM control the CCC? Also what benefits would the newer PCM offer over the older one? on a stock CCC LG4 (L69) 305? (or eventually a XE256 modded 305?)
Old Nov 11, 2011 | 11:27 AM
Ronny's Avatar
CCC? My error. you would need to go EFI.
Old Nov 11, 2011 | 12:00 PM
oh, ok. gotcha, if i was TBI, or TPI, I would have done that for sure, thanks!
AussiePr0nCar
Mar 6, 2020 04:04 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
