Just got a 16198259 ecm
Engine: 89' 305tpi
Transmission: AX15
Axle/Gears: 4:11
Im looking for ways to verify what this is and contains.
The sticker on the housing says 16198259, the blue chip inside says apyy 1613.
Car: 1985 IROC-Z28
Engine: LB9
Re: Just got a 16198259 ecm
APYY looks to be for a 89 F-body with the 5.0TPI, a 700R4, california emissions package and either 2.73 or 2.77 gears.
Engine: 89' 305tpi
Transmission: AX15
Axle/Gears: 4:11
Where do you find that info?
This was supposedly for a 5spd?
Car: 1985 IROC-Z28
Engine: LB9
well, i got that info from the CATS CalData...
i'm trying to verify it with GM info:
http://tis2web.service.gm.com/tis2web
if you grab a VIN from a same year vehicle and engine(cars.com usually works for me), you can select trans and emissions packages and see what applied.
it looks like for an 89 with a F code motor with automatic and california emissions, the factory released ANYZ and APYY.
Engine: 89' 305tpi
Transmission: AX15
Axle/Gears: 4:11
I went to cars.com, but cant find any vins. ?
What is the dif between proms for Auto and Manual? (I am running a manual)
I double checked. The guy said this is an 89' Camaro LB9 with T5 trans.
Car: 1985 IROC-Z28
Engine: LB9
http://www.cars.com/for-sale/used/ch...Id=2102&rn=150
i then opened this ad:
http://www.cars.com/go/search/detail...5&aff=national
and grabbed the VIN of the car. notice the 8th digit in the VIN is F, that's the engine.
so we paste that car's VIN into the GM site, select automatic, then california, and you'll see APYY.
someone has their wires crossed.
Transmission: 5-speed/T-5
I concur, the info I have also indicates 1989 5.0L, Auto. ECM is a 1227165.
Engine: 89' 305tpi
Transmission: AX15
Axle/Gears: 4:11
Thank you fellers.
That ebay seller is gonna get a poopy feedback.
Although im gonna burn my own chips anyways.
Heres the ad.
http://cgi.ebay.com/ebaymotors/ws/eB...T#ht_500wt_956
Heres the ad.
Engine: 89' 305tpi
Transmission: AX15
Axle/Gears: 4:11
efiguy
Sep 27, 2015 01:30 PM
