Should I Megasquirt or ECM Swap?
Car: 87 IROC Z28
Engine: 5.7 TPI
Axle/Gears: BW 9 Bolt
As of right now, I have a completely stock 5.7 TPI engine in my 1987 IROC-Z. My MAF randomly throws codes and then the code goes away. I've been thinking of doing a speed density ecm swap just to get rid of the MAF. I do plan on adding a turbo either late this year or early next year. I want to do my own tuning and want to use a wide-band O2 and would love to try tuning my own car. So I am asking for help on deciding what I need to do next? Again, I will be running a stock TPI setup for a while.
1. Go with a Megasquirt. If so, which model and what extras to get.
2. Do the 90-92 Speed Density ECM Swap (I've found the thread on that) and practice burning PROM
Again, I would like to get rid of the MAF and possibly practice tuning a stock car before going the Boosted route.
Any help is appreciated, and Thanks in Advance
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: Should I Megasquirt or ECM Swap?
Checkout www.dynamicefi.com
Rbob is a member here and he has some neat devices... I'm getting the EBL P4 Flash soon, it can monitor / datalog, learn, tune, handle boost and tons of other things... and pretty much plugs right in...
Rafael
Rafael
Yup the EBL would be great for that car. Only reason to go prom burning equiptment instead is if you were going to do more than one car. If so check out Moates website.
Car: 87 IROC Z28
Engine: 5.7 TPI
Rafael
Rafael
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
You could also wait a few months and buy Haltech's new Sport G.M. ecm...
It's a 2 wire swap to install and has aux inputs and outputs for Wideband egt etc.
Transmission: TH400
If you understood how much better the EBL is for your application, you wouldn't even consider mega-squirt.
