IAC.. Holley.. MOPAR!!
Old Aug 20, 2012 | 05:19 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I just realized the Holley Commander 950 throttle bodies (1,000 cfm 4bbl) use MOPAR Iac valves...
I've used 3 of these in combos over the years and always had trouble with idle.. Never thought to check if it was an actual GM IAC..
Apparently the pinouts are different..
Anyone know of a PWM iac that will use this mounting pattern? The Ford's all look huge.
-- Joe
Old Aug 20, 2012 | 07:18 PM
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
Re: IAC.. Holley.. MOPAR!!
-- Joe
i have one from my mustang TB i can look at, iirc its actually a little smaller
Old Aug 21, 2012 | 05:21 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
That would be cool. Does it appear to use the same mounting pattern?
I noticed some fords have a two piece, so the iac actually bolts to the housing which in turn bolts to the intake.
-- Joe
Old Aug 22, 2012 | 09:53 AM
EagleMark's Avatar
That looks identical to Holley 4 barrel TBI units and stock Chevy BB IAC...
http://www.rockauto.com/catalog/moreinfo.php?pk=88845
Old Aug 22, 2012 | 10:06 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It is, I found the difference between the Mopar and GM is simply the pinout.
http://www.megamanual.com/ms2/ewIAC.gif
-- Joe
Old Aug 22, 2012 | 11:28 AM
EagleMark's Avatar
Must be wrong link?
Even some of the screw in IAC have 2 wires crossed between SB and BB in wiring diagams.
Old Aug 22, 2012 | 01:12 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Must be wrong link?
Must be why some of the folks say to change the pinouts when going from different code masks.
-- Joe
Old Aug 29, 2012 | 01:45 PM
77nomad's Avatar
Don't know if this will help you or not.
http://www.chevytalk.org/fusionbb/sh...hp?tid/245452/
Old Aug 31, 2012 | 05:37 PM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
The above is only for the early HP and Dominator ECMs
Old Aug 31, 2012 | 05:51 PM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
The Holley body IAC's are 4 pins in a row ---- GM is square _ _
_ _
The Holley ones are Standard Motor Parts # AC416 around $55 dollars (2000 Dodge Ram 1500 if I remember) The Standard Part# is correct for sure tho.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
dusterbd
Sep 29, 2015 08:40 AM
Street Lethal
Sep 7, 2015 01:09 PM
Stell1579
Jun 18, 2001 07:24 PM
fiream
Jun 6, 2001 10:43 PM
