cant get datamaster or tunerpro to work?plz help
i dont know what im doing wong . is there a different cable than the one from my 1991 syclone . it should be the same one right? i cant get any readings
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: cant get datamaster or tunerpro to work?plz help
You might want to start out telling what vehicle your working with and cable you are using. If this is a 1227165 ecm you need to use a 10k resister to start data flow. Are you using the correct definition ? Have you verified the driver for your cable ? Baud rate ?
ok i have a 1987 iroc tpi 305 . im not sure what cable it is . i got the cable with my 1991 gmc truck and it works with datamaster fine . i dont know if it has a resistor or not i thought it would work , what do i need to start .thanks for any info
Engine: Lb9
Transmission: M20
If there is not a switch on the cable assemble back probe the aldl a to b with a 10k resister and try to establish a connection the 87 would be $32B.
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
http://lmgtfy.com/?q=Ohms+law
Engine: Lb9
Transmission: M20
you just need one , it get placed on the back side of the aldl pin A to B
