Cooling fan is running as soon as engine started
Hi, I have a tpi setup with a 165 (maf system) on a conversion vehicle, The car has a surging idle and stalls sometimes. Also the cooling fan runs all the time. At the Ecm pin C1 is the cooling fan output. it is not grounded with key on but as soon as i start the engine the computer grounds this circuit. I have already tried 2 other ECMS with the same results.. any ideaS?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Cooling fan is running as soon as engine started
I would imagine its all with the same memcal ? Try grounding D11
Engine: Lb9
Transmission: M20
Depending on the programing the ecm will expect D11 to be n/o or n/c
Thanks, that worked when I grounded D11 the fan works at it should, now if i could get rid of this hunting idle and stalling I would be good to go!
Engine: Lb9
Transmission: M20
Does it hunt just when you are slowing down ?
On a cold start it will idle at a decent rpm 800 or so, but once it warms up it starts jumping around then wants to die , the only way to keep it running is to turn the throttle stop screw up then it will stay running but at like 1000rpm or more, its a new IAC and the counts start at 80 and when it gets hot go to 0 when it won't idle
Engine: Lb9
Transmission: M20
Have you set the minimum idle speed with the iac commanded in ?
Is this a automatic ? And are you making use of the park neutral adder ?
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Regarding the radiator fan issue: Very important question here (Speaking from personal experience). Is your A/C still intact or was it deleted?
Car: 1985 Z28
If the body line is present, tell me if this connector is plugged into a switch on it.
Engine: Lb9
Transmission: M20
In park or neutral when b10 is grounded the ecm will add to the target rpm to help aid with the engine load during transition into gear.
Car: 1985 Z28
Car: 86 IROC-Z
Engine: 355
Hello, I am having a similar problem with the fan running all the time! I used to have ac but removed it. Any advice?? Thanks.
Engine: Lb9
Transmission: M20
If your car is tpi and you have removed the ac ground pin D11 of the ecm or the blue wire from D11.
Car: 1985 Z28
88+ didn't have this problem when the switch was unplugged because they changed the circuit to normally open.
theshackle
Mar 5, 2017 06:37 PM
