383 tpi with 165 ecm
Car: 1986 Z28
Engine: 383 TPI
Axle/Gears: 4.10
I'm attempting to tune my 383 tpi with maf using the Moates AutoProm. I have the edelbrock long tube runner setup with 58mm throttle body, #24 injectors, mild cam .444 int/exh and factory cast iron heads. The engine has a very unstable idle fluctuating between 800 and 1100 rpm. At this point I have replaced the IAC and reset the TPS. I have checked for vacuum leaks and haven't been able to find any. The idle problem still exists and I'm starting to wonder if my ECM is bad... I noticed that on the data-log of the engine sitting at idle the "target air fuel ratio" (not the actual afr) has huge spikes in it.. Shouldn't this be flat lined at 14.7?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 383 tpi with 165 ecm
What changes to the timing table and desired idle rpm tables have you made?
Also are you positive there are no vacuum leaks?
Car: 1986 Z28
Engine: 383 TPI
Axle/Gears: 4.10
So far the best idle setting is at 800 rpm but it still fluctuates up to 1100. When I raise the idle to 900 it fluctuates up to 1200 or 1300 rpm. If I take the idle down to 700 rpm the engine wants to stall.
I checked for vacuum leaks by spraying carb cleaner around the intake, runners and throttle body and listening for an increase in rpm. Do you have a better method to check for vacuum leaks?
Car: 89 Iroc-z
Transmission: TH400
Starter fluid is sometimes used around intake but just be careful
How much duration on the cam? What you can try is lock out the timing aroun the idle cells. Target 800-850 if somewhat medium large cam. Log the car at idle and see what lv8 values you are hitting. Bigger cams need more timing than stock cams. Depending on size it may need 25-30 deg just at idle. After you see what the idle lv8 is, go to timin table and lock all cells around that idle rpm and lv8 value at the same value. This will prevent timing from fluctuating and in return, help keep rpms stable.
Next step is to work fueling. Maf table 1 for this and monitor o2 sensor data, blms if trying closed loop. Wideband can help some here. Find the fueling it wants. Can read plugs to see mixture, you want light tan at idle. Not to white or to dark. Also can monitor idle vacuum. The closer you are to ideal idle air fuel and timing, generally see most vacuum
Car: 1986 Z28
Engine: 383 TPI
Axle/Gears: 4.10
This is great information, I will give this a try tomorrow and let you know how it goes.
Car: 89 Iroc-z
Transmission: TH400
That cam shouldnt have much issue at all. But never know with these cars. Keep playing with it.
Car: 1986 Z28
Engine: 383 TPI
Axle/Gears: 4.10
How can I fix that problem? I see Decel Enleanment in the scalars but I'm not sure if I should mess with it.
Car: 89 Iroc-z
Transmission: TH400
Can play with maf table 1 at low grams/sec flow as well as stall savers. Adjust the rpms and spark advance there. Generally i raise them up the same difference as your new cam idle speed minus stock idle speed, give or take. Stall saver rpms usually are hundred to 200 rpm below actual idle
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
This is almost identical to the issue I am having...same engine, same ECM, same injectors...Cam is 218/224. Thanks for the ideas!
Car: 89 Iroc-z
Transmission: TH400
As mentioned earlier above, after you burn chip with desired idle speed, you need to set min idle speed via the throttle body screw and reset iac
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Did you replace the intake base? If so you could've slipped an intake gasket and could be sucking from the crankcase. I've seen this many time before.
There are two ways to check this. The first...
Remove BOTH crankcase breather while the engine is running. Then put your thumb on both or if you don't have monkey arms like me, have a buddy plug one while you do the other. You'll feel your thumb suck in.
The second...
Pull the plugs, one will be oil soaked.
The second...
Car: 1986 Z28
Engine: 383 TPI
Axle/Gears: 4.10
Car: check
Engine: check
Transmission: check
Likely need to disable the stall saver. The reason is that it reverts back to the base timing, which on modified engines causes it to stall. I have a write up on this someplace, let me find it and I'll post a link.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Ignore the title, more info inside the thread:
https://www.thirdgen.org/forums/diy-...ver-sa-8d.html
RBob.
RBob.
Sanjay
Aug 12, 2015 03:41 PM
